Home » Newcomers » Newcomers » No build path option in Eclipse(64-bit Mac)
No build path option in Eclipse [message #987294] Sun, 25 November 2012 14:33 Go to next message
Sebastian Osiński is currently offline Sebastian Osiński
I use the newest Eclipse on 64-bit Mac and when i right-click on any folder in project, I don't have "Build Path" option, I tried to make new projects like some simple Hello World, just to test, if it's my fault, but on all of them it's missing.
Re: No build path option in Eclipse [message #987324 is a reply to message #987294] Mon, 26 November 2012 01:50 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
Sebastian,
You've installed which Eclipse Package? Are you looking in the
Properties wizard for that? Only the project has a whole has Java Built
Path properties, not its subfolders.
Re: No build path option in Eclipse [message #987421 is a reply to message #987324] Mon, 26 November 2012 09:42 Go to previous messageGo to next message
I've installed Eclipse Juno 4.2 SR1 for Java Developers 64bit Mac. When I click on the project there's no such option as build path. Also when i make a new source folder(New>Source Folder) and I delete it later I've got an error Project is missing required source folder and I have to edit .classpath file
Re: No build path option in Eclipse [message #987453 is a reply to message #987421] Mon, 26 November 2012 11:45 Go to previous messageGo to next message
Dani Megert is currently offline Dani Megert
Are you sure that you created a 'Java Project'?
Dani
Re: No build path option in Eclipse [message #987802 is a reply to message #987453] Wed, 28 November 2012 03:56 Go to previous messageGo to next message
Yes, it's a Java Project
Re: No build path option in Eclipse [message #987920 is a reply to message #987802] Wed, 28 November 2012 11:33 Go to previous message
Extreme Java is currently offline Extreme Java
Have you tried looking at Right Click project -> Properties -> Java Build Path
Can you post relevant screenshots here.
Previous Topic:Import declarations missing in Outline
Next Topic:ECLIPSE in MOBILE
Current Time: Sat May 25 12:29:50 EDT 2013
Powered by FUDForum. Page generated in 0.02035 seconds
