Home » Eclipse Projects » DTP » DSE has add new connection options greyed out(Unable to add Database Connections in DSE for any 'Connection Profile Types')
DSE has add new connection options greyed out [message #987275] Sun, 25 November 2012 09:52 Go to next message
manjari nandi is currently offline manjari nandi
I recently migrated to 64bit Windows 7
Installed 32 bit Eclipse Helios, 32 bit JDK 1.6.022
Installed the data tools.
Installed EclipseLink for JPA
Installed Oracle 11g client, as well as oraclexe as a last resort to JDBC Connectivity
Added User library with ojdbc6.jar
Problem:
DSE is not listing any database drivers for any vendor type. The ' new driver definition' screen has all the options greyed out and will not allow adding jars to the jar list
Any help will be much appreciated
[Updated on: Mon, 26 November 2012 12:40]
Report message to a moderator
Re: DSE has add new connection options greyed out [message #987467 is a reply to message #987275] Mon, 26 November 2012 12:41 Go to previous messageGo to next message
I am specifically trying to connect to a oracle database
Re: DSE has add new connection options greyed out [message #987724 is a reply to message #987467] Tue, 27 November 2012 13:27 Go to previous message
Solved the problem by setting eclipse to run in Windows XP compatibility mode and 'run as administrator by right clicking eclipse.exe ->properties.
Previous Topic:No Available Driver Templates in Indigo EE (64bit)
Next Topic:Postgres 8.3 Schema not expanding in Data Source Explorer
Current Time: Wed May 29 04:25:38 EDT 2013
Powered by FUDForum. Page generated in 0.05509 seconds
