| OleFrame&OleClientSite for Excel [message #987628] |
Tue, 27 November 2012 06:12  |
bogdan toma Messages: 32 Registered: February 2010 |
Member |
Hello all,
i am opening excel files in my swt application; so i am using OleFrame& OleClientSite:
this.frame = new OleFrame(this, SWT.NONE);
this.clientSite = new OleClientSite(frame, SWT.NONE, "Excel.Sheet",
file);
this.clientSite.doVerb(OLE.OLEIVERB_INPLACEACTIVATE);
Everyhting is ok, except the fact that the Excel displays a "Save" button (in quick access toolbar).
When this button is pressed the file is not saved.
The same way happens for the Eclipse Editor for "excel" files.
If I press the "Save" button inside excel nothing happens;
If I press the "Save" button on the eclipse toolbar the button is saved.
Is there any chance that I can do the save when "inside" button is pressed ?
Is there any chance to hide this button ?
I am using org.eclipse.swt_3.7.0.v3735b.jar & Office2010 (program ID = Excel.Sheet.12).
Thank you.
| Re: OleFrame&OleClientSite for Excel [message #1027243 is a reply to message #987628] |
Tue, 26 March 2013 14:47  |
Binko Binev Messages: 19 Registered: June 2012 |
Junior Member |
I do not think that it is possible. Because the embedded Excel workbook does not know where it is - it is just "Workbook in main".
Yet you can pass the file path as a custom document property for example, and call a macro on pressing the save button. I am not sure if there is an OLE event for saving the file to do that from the Java code.
In my app, I have icons in the main toolbat for save and save as, especially as Excel does not save correctly as PDF for tables with more columns than pass on a page (if it has page breaks, so I have to remove them).
Do you have also worked with Word.
My Word crtashes in this method
* Returns the row in the table with the given index
* @param tableVar - table variant
* @param rowIndex - row index
* @return rowVariant - row Variant
* @throws OleException
public static Variant getRow(Variant tableVar, int rowIndex) throws OleException {
OleAutomation tableAuto = tableAuto = tableVar.getAutomation();
OleUtils.printAutomation(tableAuto);
Variant rowsVar = null;
while (rowsVar == null){
rowsVar = tableAuto.getProperty(101/*Rows*/);
OleAutomation rowsAuto = rowsVar.getAutomation();
Variant rowVar = rowsAuto.invoke(0/*Item*/, new Variant[]{new Variant(rowIndex)});
return rowVar;
Sometimes it works for a large number of rows, some times it crashes - the rowIndex is arbitrary. I just do not know how to prevent it from crashing.
Any ideas?
FUDForum. Page generated in 0.01700 seconds
