Home » Modeling » EMF » Schema location for cascaded ecore models "initialize by loading"
Schema location for cascaded ecore models "initialize by loading" [message #987614] Tue, 27 November 2012 05:35 Go to next message
Eclipse User
I have 2 Ecore models A and B which use the "initialize by loading"
option. The B model extends classes from A.
I have altered each loadPackage() to call createResource() with the URI
of the packageFilename.
But when I serialize an instance of model B, a proper schema location is
only emitted for model B. When I load the resulting .xmi file into the
generic EMF editor it chokes on unknown features which stem from model A.
1) Is this supposed to work as I have described? What could I have
forgotten?
2) Is there any way to register the static EPackages with the package
filename URI WITHOUT having to touch generated code? I _really_ like
being able to wipe all *.java files, refresh and regenerate.
Best Regards
Marius
Re: Schema location for cascaded ecore models "initialize by loading" [message #987623 is a reply to message #987614] Tue, 27 November 2012 05:55 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
Marius,
Comments below.
On 27/11/2012 11:35 AM, Marius Gröger wrote:
> Hello,
What does these URIs look like?
> forgotten?
Have a look at what happens in
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.addNamespaceDeclarations()
and particularly at what's happening at this line:
if (javaImplementationLocation != null || (uri == null ?
nsURI != null : !uri.toString().equals(nsURI)))
It will save a schema location only if the resource's URI is different
from the nsURI.
No.
> Best Regards
> Marius
Re: Schema location for cascaded ecore models "initialize by loading" [message #987651 is a reply to message #987623] Tue, 27 November 2012 07:35 Go to previous messageGo to next message
Eclipse User
>> Hello,
> from the nsURI.
I know about the uri vs nsURI thing and have thus modified the static
packages accordingly. That changed URI looks fine and points to the
..ecore file.
Actually I think I found the root cause: when using the "initialize by
loading" option, a copy of the original .ecore is placed inside the src
directory where the generated sources are.
This happens for both my model A and B. But that generated .ecore for
model B does not know the location of the generated .ecore of model A.
The issue shows already when I open the generated .ecore for model B: it
complains that I has no knowledge of model A.
So it appears I need to modify the generated code even more to let it
point to some common directory containing all related models. Which is
not so easy at all since A and B are in different plugins.
Marius
Re: Schema location for cascaded ecore models "initialize by loading" [message #987696 is a reply to message #987651] Tue, 27 November 2012 11:13 Go to previous message
Marius,
Comments below.
>>> Hello,
>> from the nsURI.
> .ecore file.
Yes, that's what it sounds like.
Yes.
No, it refers to the other model via its nsURI.
Yes, it's intended for loading at runtime only by the generated package
implementation.
The original Ecore files along with their GenModels are generally
available at runtime as well. They can generally be accessed by
platform:/plugin/<plugin-id>/model/<ecore-file-name>.ecore.
> Regards
> Marius
Previous Topic:[CDO] Decomposing model into several repo & use same DB
Next Topic:Unable to load model which was created using the same emf
Current Time: Thu May 23 21:02:58 EDT 2013
Powered by FUDForum. Page generated in 0.03489 seconds
