| [CDO] Decomposing model into several repo & use same DB [message #987308] |
Sun, 25 November 2012 16:45  |
Cristian Mising name Messages: 72 Registered: July 2009 |
Member |
I would like to decompose my model into several repositories, that contain references between them. The reason for doing this: I would like to have some of the repositories stored locally. And because CDO doesn't allow a partial checkout of the repository, a solution would be the use of multiple repositories, instead of a single, bigger one.
Question 1) is it possible that all my repositories use the same database? All the examples that I found about CDO: 1 repo = 1 DB.
Question 2) Should I expect severe performance penalties because of this approach? E.g. 1 resource/repo with 10000 objects vs 10 resources/repositories with 1000 objects each vs 100 resources/repositories with 100 objects each?
Thank you in advance,
Cristian
| Re: [CDO] Decomposing model into several repo & use same DB [message #987546 is a reply to message #987308] |
Tue, 27 November 2012 00:57  |
Eike Stepper Messages: 5153 Registered: July 2009 |
Am 25.11.2012 22:45, schrieb Cristian Mising name:
> Hello,
> repo = 1 DB.
I think it should be possible (easy to try out), but it may depend on the physical system used. You may need to declare
separate schemas or so.
Each repository has its own set of infrastructure services (revision manager/cache, package registry, security realm,
and, and, and...). You'd need additional server resources for all of them. Similarly for the sessions on the clients.
Inter-repo cross references (and containment proxies) are stored as URLs that need more storage space/bandwidth and that
can only be resolved by clients with properly configured resource sets).
Multi-repo commits require a CDOXATransaction which is somewhat complexer and more time consuming.
Unfortunately I can hardly comment on the exact performance differences. They depend on various things like the store
being used, the DB system being used, etc. If you make a prototype and measure yourself, I'd appreciate if you would
write them to the wiki and let us know ;-)
Cheers
/Eike
http://www.esc-net.de
FUDForum. Page generated in 0.01926 seconds
