| Out of memory error in hudson [message #986165] |
Mon, 19 November 2012 04:34  |
minu martin Messages: 2 Registered: November 2012 |
Junior Member |
I am getting out of memory error in hudson while using Insight for CI plugin. Hudson memory config is as given below:
export CATALINA_OPTS="-Xmn100m -Xms512m -Xmx512m -XX:MaxPermSize=768m"
export JAVA_OPTS="-Xmn100m -Xms512m -Xmx512m -XX:MaxPermSize=768m"
Can someone suggest is anything wrong with the memory configuration?
Stack trace of error:
SEVERE: Weaving class problem. Original class has been returned. The error was caused because of: java.lang.OutOfMemoryError: PermGen space
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClassCond(ClassLoader.java:632)
at java.lang.ClassLoader.defineClass(ClassLoader.java:616)
at java.lang.ClassLoader.defineClass(ClassLoader.java:466)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:139)
at org.aspectj.weaver.bcel.ExtensibleURLClassLoader.defineClass(ExtensibleURLClassLoader.java:63)
at org.aspectj.weaver.loadtime.WeavingURLClassLoader.defineClass(WeavingURLClassLoader.java:151)
at org.aspectj.weaver.bcel.ExtensibleURLClassLoader.defineClass(ExtensibleURLClassLoader.java:97)
at org.aspectj.weaver.bcel.ExtensibleURLClassLoader.findClass(ExtensibleURLClassLoader.java:52)
at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
at org.aspectj.weaver.loadtime.WeavingURLClassLoader.defineClass(WeavingURLClassLoader.java:148)
Nov 19, 2012 6:50:50 AM org.aspectj.weaver.tools.Jdk14Trace error
Nov 19, 2012 6:50:55 AM org.aspectj.weaver.tools.Jdk14Trace error
FUDForum. Page generated in 0.01823 seconds
