Home » Modeling » EMF » [Xcore] Error importing ecore.EcorePackage in generated class
[Xcore] Error importing ecore.EcorePackage in generated class [message #986917] Thu, 22 November 2012 06:18 Go to next message
Jan Rosczak is currently offline Jan Rosczak
I am using Xcore 1.0.1 in Eclipse 3.8. I have created an Xcore/Xtext project, defined my model und everythings worked like a charm.
Now I want to build my plugin with tycho/maven. As far as I figured it out, I need a mwe2 workflow invoking the XcoreGenerator.
In order to solve dependencies I added the plugins org.eclipse.emf.mwe2.launch and org.eclipse.emf.ecore.xcore as optional dependencies. Running my maven build everything seems to work.
But, when I clean/build the project in the Eclipse workspace I get an error in the generating class: The import ecore cannot be resolved. Looking in the PackageImpl class I see the import "ecore.EcorePackage". Why is this package shortened?
Removing the two optional dependencies mentioned above, clean/build in the workspace works. Adding the optional dependencies client/build in the workspace fails.
Am I doing something wrong or what can I do to resolve this?
Jan
Re: [Xcore] Error importing ecore.EcorePackage in generated class [message #986983 is a reply to message #986917] Thu, 22 November 2012 12:09 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
Jan,
Comments below.
On 22/11/2012 12:18 PM, Jan Rosczak wrote:
Someone else complain about this recently. It seems to boil down to a
problem with the GenModel for Xtext not specifying Ecore.genmodel's
GenPackage as a usedGenPackage.
If you can share a self contained zip file with projects demonstrating
this problem, I'll be able to track it down; I think there might already
be an Xtext bugzilla for this...
> Thanks
> Jan
Re: [Xcore] Error importing ecore.EcorePackage in generated class [message #987385 is a reply to message #986983] Mon, 26 November 2012 06:53 Go to previous message
Hi Ed,
thanks for your quick response. I am currently not able to publish my project (company policy), but I tried to setup a dummy project that exhibits the same error, with no success. I will come back when the errors presents itself in a project I can share.
Jan
Previous Topic:[CDO] Server does not send 'Respository ADDED' event
Next Topic:Querying EMF model with Xpath
Current Time: Sat May 25 03:49:28 EDT 2013
Powered by FUDForum. Page generated in 0.02705 seconds
