Home » Eclipse Projects » Eclipse Platform » example of opening an IFolder and a filesystem directory in a CompareEditor?
example of opening an IFolder and a filesystem directory in a CompareEditor? [message #987310] Sun, 25 November 2012 17:32
Tom H is currently offline Tom H
I'd like to open an IFolder structure in a 2-way compare with a filesystem directory that is not in the workspace.
I see the ResourceCompareInput, and could use this as an example, but it is an internal package - org.eclipse.compare.internal so cannot be directly utilized.
What is the suggest way to proceed here?
should I use the ResourceCompareInput as an example and copy those classes over into my plugin, or is there a simpler way to achieve a 2-way directory compare?
Tom
Previous Topic:using the compare API
Next Topic:Eclipse startup time too long
Current Time: Thu May 23 13:36:35 EDT 2013
Powered by FUDForum. Page generated in 0.01669 seconds
