Home » Modeling » EMF » getting editing domain from resource set
getting editing domain from resource set [message #400882] Fri, 05 May 2006 11:57 Go to next message
Marc Moser is currently offline Marc Moser
On Mon, 20 Jun 2005 11:55:07 -0400,
Ed wrote:
Jaap,
In the generated editors, the resource set knows the editing domain so
typically this should work well.
We naively looked for a getEditingDomain() in ResourceSet, but obviously
its not there.
Does anyone know how to get the editing domain from a resource set
in the generated EMF editor?
Thanks in advance,
Marc
Re: getting editing domain from resource set [message #400886 is a reply to message #400882] Fri, 05 May 2006 12:23 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
--------------050203010407090005020500
Marc,
You'll probably just want to reuse this method from
AdapterFactoryEditingDomain:
static public EditingDomain getEditingDomainFor(EObject object)
Resource resource = object.eResource();
if (resource != null)
IEditingDomainProvider editingDomainProvider =
(IEditingDomainProvider)EcoreUtil.getExistingAdapter(resourc e,
IEditingDomainProvider.class);
if (editingDomainProvider != null)
return editingDomainProvider.getEditingDomain();
else
ResourceSet resourceSet = resource.getResourceSet();
if (*resourceSet instanceof IEditingDomainProvider*)
EditingDomain editingDomain =
((IEditingDomainProvider)resourceSet).getEditingDomain();
return editingDomain;
else if (resourceSet != null)
(IEditingDomainProvider)*EcoreUtil.getExistingAdapter(resour ceSet,
IEditingDomainProvider.class)*;
return null;
> Ed wrote: Jaap,
> its not there.
> Thanks in advance,
> Marc
<html>
<head>
http-equiv="Content-Type">
</head>
Marc,<br>
<br>
AdapterFactoryEditingDomain:<br>
<blockquote><small>
Re: getting editing domain from resource set [message #987191 is a reply to message #400886] Sat, 24 November 2012 05:30 Go to previous message
Victor Zalevski is currently offline Victor Zalevski
Thank you, Ed!
This post helped me a lot
Previous Topic:Customizing saving Model to XMI via XMISaveImpl options
Next Topic:[EMF Compare] UML: Added Element with Stereotyp
Current Time: Sat May 25 10:33:17 EDT 2013
Powered by FUDForum. Page generated in 0.03589 seconds
