Home » Eclipse Projects » Eclipse 4 » Window icons in several sizes
Window icons in several sizes [message #986670] Wed, 21 November 2012 05:41 Go to next message
Dirk Fauth is currently offline Dirk Fauth
I started my Eclipse 4 application in the context of Eclipse 4.3 M3. As described in another topic, configuring the window icon in the application model will now show the window icon correctly in the window itself.
Now there is still the issue that it is not possible to supply multiple sizes/resolutions for window icons, like it was possible in Eclipse 3.x via product branding. For example, on Windows 7 the icon shown in the task bar is the same as used within the window itself. You can expect that this looks really ugly as the icon shown in the task bar is bigger than in the window.
For me it looks like the configuration of the product branding isn't evaluated in Eclipse 4. Is this correct?
I can remember that the bug for missing window icons is refering to this issue as well. Am I correct that this is still open?
After doing a bit more research, yes this bug seems to be still open:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=280825
Greez,
Dirk
[Updated on: Wed, 21 November 2012 05:50]
Report message to a moderator
Re: Window icons in several sizes [message #987085 is a reply to message #986670] Fri, 23 November 2012 06:36 Go to previous messageGo to next message
Is there some workaround on this issue? Because looking at the Eclipse IDE itself, there are window icons in several sizes. I know it uses the compatibility layer, but maybe there is an option to do this now on Eclipse 4 I haven't found yet?
Re: Window icons in several sizes [message #987093 is a reply to message #987085] Fri, 23 November 2012 07:28 Go to previous messageGo to next message
Christoph Keimel is currently offline Christoph Keimel
Hi Dirk,
the code in WBWRenderer, which is responsible to set the image looks like this:
if (wbwModel.getIconURI() != null && wbwModel.getIconURI().length() > 0) {
	wbwShell.setImage(getImage(wbwModel));
} else {
	wbwShell.setImages(Window.getDefaultImages());
I haven't tried it, but imho as a workaround you can leave the icon field in the model empty and use Window.setDefaultImages(Image[] images) to set the images for example on @PostContextCreate in your life cycle handler.
Hope that helps
Christoph
Re: Window icons in several sizes [message #987098 is a reply to message #987093] Fri, 23 November 2012 08:11 Go to previous messageGo to next message
Hi Christoph,
thanks for that tipp. Indeed this workaround is working. Smile
Greez,
Dirk
Re: Window icons in several sizes [message #1005804 is a reply to message #987098] Mon, 28 January 2013 14:35 Go to previous messageGo to next message
Rafael Fogel is currently offline Rafael Fogel
Christoph, can you post a more complete code? I am facing the same problem and I didn't understand what you said.
Thanks.
Re: Window icons in several sizes [message #1005829 is a reply to message #1005804] Mon, 28 January 2013 16:21 Go to previous messageGo to next message
Hi Rafael
I don't have any code ready, since I am happy with a single icon which I define in the application model (Bug 280825 has been fixed).
Otherwise, you can use the API in JFace 'Window' class to set the multiple images. Maybe Dirk has some sample code for you?
If you want to know what is happening under the covers, put a breakpoint in WBWRenderer.
Greetings
Christoph
Re: Window icons in several sizes [message #1005876 is a reply to message #1005829] Tue, 29 January 2013 02:39 Go to previous messageGo to next message
yes I have a sample code. I created a lifecycle hook and implemented the following method:
@PostContextCreate
public void postContextCreate() {
	Window.setDefaultImages(new Image[] { //add your images here });
Hope that helps,
Dirk
Re: Window icons in several sizes [message #1008724 is a reply to message #1005876] Wed, 13 February 2013 13:12 Go to previous messageGo to next message
Hi Dirk, can you tell me how you are loading those images? The setImage function doesn't accept any image I load.
Re: Window icons in several sizes [message #1008950 is a reply to message #1008724] Thu, 14 February 2013 02:44 Go to previous messageGo to next message
I load Images like explained here http://www.vogella.com/articles/Eclipse3RCP/article.html#tips_loadimages
Re: Window icons in several sizes [message #1009109 is a reply to message #1008950] Thu, 14 February 2013 08:04 Go to previous message
Thank you very much Dirk. Working beautifully now.
Previous Topic:Getting the application Shell at start?
Next Topic:IEventBroker inside of the LifeCycle?
Current Time: Thu May 23 17:45:20 EDT 2013
Powered by FUDForum. Page generated in 0.02262 seconds
