| The type org.eclipse.swt.widgets.Button cannot be resolved. It is indirectly referenced from require [message #973854] |
Tue, 06 November 2012 12:19  |
Alex Kipling Messages: 212 Registered: July 2012 |
Situation: I have an Eclipse RCP Application, which I am trying to build with tycho plugin for Eclipse.
When I am executing my Eclipse Application inside of the IDe - the Application is executed normally.
When using tycho to build the Application - the following error is thrown:
The type org.eclipse.swt.widgets.Button cannot be resolved. It is indirectly referenced from required .class files
What I did :
In other cases where a "missing requirenments" exception was thrown, which I found - a missing transitive plugin-dependency was the reason(https://issues.sonatype.org/browse/TYCHO-400)
In my case an SWT widget "Button" is missing, so I am trying to import swt. SWT is platform dependant so I am importing swt inside of the product, as described here:
http://wiki.eclipse.org/Tycho/FAQ
Anyway, during compilation the error occurs again.
Question:
Do someone have any Idea, how to solve this Problem?
FUDForum. Page generated in 0.01589 seconds
