Home » Modeling » ATL » Executing ATL transformation programatically issue
Executing ATL transformation programatically issue [message #986996] Thu, 22 November 2012 12:51 Go to next message
Mehdi Missing name is currently offline Mehdi Missing name
I have an ATL transformation that works just fine under the ATL run configuration with these informations:
As input Metamodel i have a XSD file
As output Metamodel a Ecore Metamodel
Launching an ATL transformation with only Ecores as input/output metamodels programmatically is no problem.
The problem here is how to launch the ATL transformation programmatically within a Java application with a XSD as input metamodel and an Ecore as an output metamodel?
Any ideas ?
Thank you in advance.
Re: Executing ATL transformation programatically issue [message #987029 is a reply to message #986996] Thu, 22 November 2012 22:43 Go to previous messageGo to next message
Erik Vonderheid is currently offline Erik Vonderheid
Refering to your previous post http://www.eclipse.org/forums/index.php/m/985913/#msg_985913:
I think you'll need a ModelFactory for handling the XSD file. The ModelFactory should provide an IModel for the XSD.
Re: Executing ATL transformation programatically issue [message #987315 is a reply to message #987029] Sun, 25 November 2012 21:17 Go to previous message
Thank you for your response,
But i have some problems understading what you mean by "need a ModelFactory for handling the XSD file" ?
And if possible do you have any documentation or Examples i can read ?
Previous Topic:ATL.ecore validation fails
Next Topic:ATL Plugin
Current Time: Wed May 22 01:50:45 EDT 2013
Powered by FUDForum. Page generated in 0.10934 seconds
