Home » Modeling » GMF (Graphical Modeling Framework) » EEF referenced View
EEF referenced View [message #981791] Mon, 12 November 2012 12:53 Go to next message
Almamy Ndiaye is currently offline Almamy Ndiaye
Hi everybody,
I have a question about EEF referenced View. When I add a referenced view, the property sheet doesn't load referenced values.
In the XXPropertiesEditionComponent generated, the initPart method looks okay. There is a line which I think, initializes the referenced view "basePart.getXXReferencedView().setContext(elt, allResource);".
Is that right or I have to add code in this method ?
Re: EEF referenced View [message #986616 is a reply to message #981791] Wed, 21 November 2012 03:21 Go to previous messageGo to next message
Does anyone know where we can get EEF sources ?
Re: EEF referenced View [message #986618 is a reply to message #986616] Wed, 21 November 2012 03:27 Go to previous messageGo to next message
Ralph Gerbig is currently offline Ralph Gerbig
maybe EEF forum can help you further. Maybe this http://eclipsercpdev.blogspot.de/2011/10/use-eclipse-eef-as-property-sheet-for.html could give you some hints on how to proceed.
Ralph
[Updated on: Wed, 21 November 2012 03:53]
Report message to a moderator
Re: EEF referenced View [message #986967 is a reply to message #986618] Thu, 22 November 2012 10:20 Go to previous messageGo to next message
Thank you Ralph, I have customized the XXPropertiesEditionComponent to handle referenced view.
Re: EEF referenced View [message #987067 is a reply to message #986967] Fri, 23 November 2012 04:37 Go to previous message
could you please post here what did or even better put it into the GMF wiki on this page? http://wiki.eclipse.org/Graphical_Modeling_Framework/Tips This would be a great contribution from your side to the GMF Tooling project.
Ralph
Previous Topic:GMF Asymmetric grid
Next Topic:Connection between nodes created in the model, don't appear in the graphical editor
Current Time: Thu May 23 09:44:23 EDT 2013
Powered by FUDForum. Page generated in 0.02066 seconds
