Home » Eclipse Projects » Eclipse Platform » List of installed plugin(get it programmatically)
List of installed plugin [message #986760] Wed, 21 November 2012 09:51 Go to next message
Andrea Margheri is currently offline Andrea Margheri
how can I get all installed plugins programmatically? I found some examples but they don't run on Juno.
Thanks a lot!
Andrea
Re: List of installed plugin [message #989911 is a reply to message #986760] Sun, 09 December 2012 18:05 Go to previous message
Eban Escott is currently offline Eban Escott
Member
Hi Andrea,
I would use the BundleContext and invoke the getBundles method. If you are in a class without a reference to the BundleContext you can use the FrameworkUtil to get it.
Hope this helps
Eban
[Updated on: Sun, 09 December 2012 18:06]
Report message to a moderator
Previous Topic:Accessing and exporting log entries in LogView
Next Topic:Accessing ui libraries in a headless Eclipse application
Current Time: Fri May 24 15:04:26 EDT 2013
Powered by FUDForum. Page generated in 0.02197 seconds
