I am currently faced with the problem that one of our companies plugin consumes to much time in the activator. Actualy it needs to read a lot of file from the project and builds an index to perform fast queries. Since the whole application is designed to always have all data in memory, it is very difficult to delay this initialization. If I do this, I have to touch every action/command/editor/view to support some kind of "wait for initialization to finish" reporting, similar as it is done when saving a file in jdt while workspace is locked.
One solution I have found is setting the "equinox.statechange.timeout" config.ini to a higher value. However I haven't found a solution to increase this value during plugin-installation. Is this possible or do I have to create my own touchpoint?
May be there is a better solution for this, any other ideas?
The following stacktrace comes from the attached demo project and shows that the problem may be caused by any plugin loading an extension requiring a class from a "blocked" plugin:
org.osgi.framework.BundleException: State change in progress for bundle "reference:file:/D:/work/daten/eclipse/workspaceTest/ch.actifsource.demo.osgiTimeoutBlocking/" by thread "Thread-2".
at org.eclipse.osgi.framework.internal.core.AbstractBundle.beginStateChange(AbstractBundle.java:1087)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:297)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:268)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:463)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:400)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:476)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:345)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1207)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at ch.actifsource.demo.osgitimeoutbase.Activator$1.run(Activator.java:29)
at java.lang.Thread.run(Thread.java:662)
at ch.actifsource.demo.osgitimeoutbase.Activator$2.run(Activator.java:51)
Caused by: org.eclipse.osgi.framework.internal.core.AbstractBundle$BundleStatusException
... 23 more
Root exception:
However I am not really satified with this solution. It would be much nicer if there where at least a hook for the Splash-Screen or something similar to give feedback about the loading progress.
