| EmbeddedXtextEditor and context for expression [message #986713] |
Wed, 21 November 2012 07:29  |
ModelGeek Mising name Messages: 347 Registered: June 2011 |
I am using EmbeddedXtextEditor for writing OCL expressions. It works fine in case of writing derivation statement of an attribute but when i want to write an OCL expression for operation's body and if operation has parameters then it does not recognize parameters. But if operation has no arguments/parameters then it works fine.
void org.eclipse.ocl.examples.xtext.essentialocl.ui.model.BaseDocument.setContext(EClassifier ecoreContext, Map<String, EClassifier> ecoreParameters)
In case of attribute derivation statement, i am passing null as ecoreParameters but incase of operation i am setting ecoreParameters arugument as map of eparameter's name and eparameterType of specific function. But doing so i am getting Exception as
at org.eclipse.ocl.examples.pivot.attributes.DataTypeAttribution.computeLookup(DataTypeAttribution.java:42)
any idea?
Cheers and thanks in advance
| Re: EmbeddedXtextEditor and context for expression [message #986734 is a reply to message #986722] |
Wed, 21 November 2012 08:41   |
org.eclipse.emf;bundle-version="2.6.0",
org.eclipse.emf.ecore;bundle-version="2.8.1",
org.eclipse.emf.codegen;bundle-version="2.8.0",
org.eclipse.emf.codegen.ecore;bundle-version="2.8.1",
org.eclipse.ocl;bundle-version="3.3.0",
org.eclipse.ocl.ecore;bundle-version="3.2.100",
org.eclipse.ocl.examples.pivot;bundle-version="3.3.0",
org.eclipse.ocl.examples.xtext.base;bundle-version="3.3.0",
org.eclipse.ocl.examples.xtext.console;bundle-version="3.3.0",
org.eclipse.ocl.examples.xtext.essentialocl;bundle-version="3.3.0",
org.eclipse.ocl.examples.xtext.oclstdlib;bundle-version="3.3.0",
org.eclipse.ocl.examples.xtext.oclstdlib.ui;bundle-version="3.3.0"
thanks for assistance
| Re: EmbeddedXtextEditor and context for expression [message #986763 is a reply to message #986752] |
Wed, 21 November 2012 10:00   |
org.eclipse.ocl.examples.pivot;bundle-version="3.3.0.v20121102-1800",
org.eclipse.ocl.examples.xtext.base;bundle-version="3.3.0.v20121102-1658",
org.eclipse.ocl.examples.xtext.console;bundle-version="3.3.0.v20121102-1658",
org.eclipse.ocl.examples.xtext.essentialocl;bundle-version="3.3.0.v20121102-1658",
org.eclipse.ocl.examples.xtext.oclstdlib;bundle-version="3.3.0.v20121102-1658",
org.eclipse.ocl.examples.xtext.oclstdlib.ui;bundle-version="3.3.0.v20121102-1658"
I have tried to debug and it seems
@Deprecated
public @Nullable Object setContext(@NonNull EssentialOCLCSResource resource, @Nullable EClassifier ecoreContext, @Nullable Map<String, EClassifier> ecoreParameters) {
CS2PivotResourceAdapter csAdapter = CS2PivotResourceAdapter.getAdapter(resource, null);
MetaModelManager metaModelManager = csAdapter.getMetaModelManager();
resource.setParserContext(new EInvocationContext(metaModelManager, resource.getURI(), ecoreContext, ecoreParameters));
return null;
is being used with parameter map is passed properly.
[Updated on: Wed, 21 November 2012 10:07] Report message to a moderator
| Re: EmbeddedXtextEditor and context for expression [message #986792 is a reply to message #986763] |
Wed, 21 November 2012 11:13  |
Ed Willink Messages: 3166 Registered: July 2009 |
I'm puzzled.
is an N-build a few weeks before M3, but all relevant changes should be
in that code.
> at
> at
> at
> at
> at
> at
should be line 43 in the current code.
(The extra line to support lookup of templated data type parameters such
as EList<T> was added just before Juno.)
I can see a mechanism for a loop for an interesting DataType declaration.
Please raise a Bugzilla and attach a zipped project.
Ed Willink
FUDForum. Page generated in 0.01878 seconds
