| Re: programmatic generation of diagrams [message #987721 is a reply to message #986964] |
Tue, 27 November 2012 13:03  |
Goood Guy Messages: 96 Registered: September 2011 |
Member |
I guess the canonial edit policy should works per default because it comes with gmf. this means if you e.g. create a new class programmatically a graphical node should be created accordingly (BTW: are you planning to use a QVTo transformation to update the UML model?)
Since I've never used the diagram generation component, I cannot tell you how to use it programmatically. I think you should take a look into the projects in [branches/0.9.X/]extraplugins/diagramtemplate/* of the papyrus svn. I think these are the projects which are responsible for diagram generation.
FUDForum. Page generated in 0.01758 seconds
