| Re: SWT Browser + XULRunner + jvm fatal error - need help on what to do [message #985671 is a reply to message #973297] |
Thu, 15 November 2012 11:16   |
Grant Gayed Messages: 2128 Registered: July 2009 |
Hi John,
I can take a guess, though without more context that's all it is. The
top-listed native frame is JVM_FindSignal, so the crash actually looks
like it's happening in the JRE (it's not just being trapped there). I
also notice in the loaded libraries list that there are Java libraries
loaded from both C:\Woodpecker\WoodpeckerVIR\Java\... and
C:\PROGRA~1\Java\jre6\... , which is generally not a good thing to do.
The C:\PROGRA~1\Java\jre6\... libraries are being loaded by the
"-Xbootclasspath/a:..." JVM startup arg, which I assume is there in
order to make applets work. The JRE at C:\Woodpecker\WoodpeckerVIR\Java
is presumably being used to launch your app (?).
So the first thing to try is to get rid of the "-Xbootclasspath/a:..."
JVM startup arg and see if it makes the crashes go away. If it does
then the fix is likely to just ensure that the JRE at
C:\PROGRA~1\Java\jre6\... is used to launch your app, since this MUST be
the same JRE that is used by native browsers to render applets AND be
pointed at by "-Xbootclasspath/a:...". If it does not help then look at
the new error log and at least confirm that Java libraries only being
loaded from C:\PROGRA~1\Java\jre6\... and nowhere else.
HTH,
Grant
On 11/6/2012 3:06 AM, János Gerevich wrote:
> We have a client who runs our program that uses an SWT Browser component.
> We have some pages where unpredictabally, about every 10. time, the JVM crashes with a fatal error. These pages seemingly only differ from other pages in that they use a javascript function created in SWT. To make matters worse, we cannot reproduce it in our development environment, but at our client it occurs on more than one computer.
> We have the fatal error log (see attachment). I never debugged such a log before, could someone help me and give me a hint on what the log says, what can we try?
> Thank you,
> John
| Re: SWT Browser + XULRunner + jvm fatal error - need help on what to do [message #985887 is a reply to message #985671] |
Fri, 16 November 2012 10:00   |
Re-reading my response, the "get rid of '-Xbootclasspath/a:...' part
misses the point by a bit. Just skip this and ensure that your app is
being launched with the JRE at C:\PROGRA~1\Java\jre6\..., so that the
the JRE at C:\Woodpecker\WoodpeckerVIR\Java\... is not involved in any way.
Grant
On 11/15/2012 11:16 AM, Grant Gayed wrote:
> Hi John,
> HTH,
> Grant
>> Thank you,
>> John
FUDForum. Page generated in 0.06878 seconds
