Home » Eclipse Projects » JFace » org.eclipse.ui.PartInitException(org.eclipse.ui.PartInitException)
org.eclipse.ui.PartInitException [message #974574] Wed, 07 November 2012 01:47 Go to next message
RP Mar is currently offline RP Mar
Member
Please how to solve this below error please kindly help me.
org.eclipse.ui.PartInitException: Could not create view: ESC_Configurator_Tool.view
Re: org.eclipse.ui.PartInitException [message #986135 is a reply to message #974574] Mon, 19 November 2012 01:54 Go to previous messageGo to next message
Supreetha H R is currently offline Supreetha H R
It would have occurred on unsuccessful attempt in creating the editor/page/view. Check if there were any exceptions thrown which stopped the creation of the view.
Re: org.eclipse.ui.PartInitException [message #986191 is a reply to message #986135] Mon, 19 November 2012 06:46 Go to previous messageGo to next message
Member
Dear Supreetha H R,
Please kindly how to make successful attempt in creating the editors/pages/views.
I debug the application also. I have 3 views in my app i.e View,Explorer View and Property View. While running the application views are not implicitly loaded properly,I am choosing views explicitly in Quick Access option,juno ide,eclipse rcp.
here is application control folow....
ApplicationActionBarAdvisor-> makeActions(IWorkbenchWindow window) {}
then control
ActionBarAdvisor->fillActionBars->
workbenchWindow->IMenuService ... etc....
Please kindly help me reg this.
Raj.
Re: org.eclipse.ui.PartInitException [message #986269 is a reply to message #986191] Mon, 19 November 2012 11:46 Go to previous messageGo to next message
Member
Dear Supreetha H R,
Please kindly help me reg my app error and how to go further proccess.
Re: org.eclipse.ui.PartInitException [message #986511 is a reply to message #986269] Tue, 20 November 2012 12:16 Go to previous messageGo to next message
Member
Dear Supreetha H R,
In the below code catch block getting the Exception. Please kindly help me.
private void makeAction() {
viewer.setContentProvider(new FileNameContentProvider());
viewer.setLabelProvider(new FileNameLabelProvider());
FileNameMockModel fileNames = ObjectFactory.commonObject.getFileNameObject();
viewer.setInput(fileNames);
getSite().setSelectionProvider(viewer);
IWorkbenchPage page = Workbench.getInstance().getActiveWorkbenchWindow().getActivePage();
try {
page.showView(View.ID);
} catch (PartInitException e1) {
// TODO Auto-generated catch block
e1.printStackTrace();
Re: org.eclipse.ui.PartInitException [message #986599 is a reply to message #986511] Wed, 21 November 2012 02:05 Go to previous message
Member
!SESSION 2012-11-21 12:23:37.832 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.7.0
Framework arguments: -product ESC_Configurator_Tool.product
Command-line arguments: -product ESC_Configurator_Tool.product -data C:\escconfiguratortool/../runtime-ESCConfiguratorTool.product -dev file:C:/escconfiguratortool/.metadata/.plugins/org.eclipse.pde.core/ESC Configurator Tool.product/dev.properties -os win32 -ws win32 -arch x86 -consoleLog
!ENTRY org.eclipse.ui 4 0 2012-11-21 12:23:55.080
!MESSAGE Unhandled event loop exception
!STACK 0
at org.eclipse.jface.action.LegacyActionTools.removeMnemonics(LegacyActionTools.java:735)
at org.eclipse.ui.internal.quickaccess.ActionElement.getLabel(ActionElement.java:53)
at org.eclipse.ui.internal.quickaccess.QuickAccessProvider$1.compare(QuickAccessProvider.java:61)
at java.util.TimSort.binarySort(Unknown Source)
at java.util.TimSort.sort(Unknown Source)
at java.util.Arrays.sort(Unknown Source)
at org.eclipse.ui.internal.quickaccess.QuickAccessProvider.getElementsSorted(QuickAccessProvider.java:57)
at org.eclipse.ui.internal.quickaccess.QuickAccessContents.computeMatchingEntries(QuickAccessContents.java:229)
at org.eclipse.ui.internal.quickaccess.QuickAccessContents.refresh(QuickAccessContents.java:108)
at org.eclipse.ui.internal.quickaccess.QuickAccessContents$4$1.run(QuickAccessContents.java:419)
at org.eclipse.swt.widgets.Display.runTimer(Display.java:4270)
at org.eclipse.swt.widgets.Display.messageProc(Display.java:3357)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2546)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3756)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:916)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:585)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
at esc_configurator_tool.Application.start(Application.java:20)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
!ENTRY org.eclipse.ui 4 0 2012-11-21 12:23:55.090
!STACK 0
at org.eclipse.ui.internal.quickaccess.QuickAccessElement.match(QuickAccessElement.java:85)
at org.eclipse.ui.internal.quickaccess.QuickAccessContents.computeMatchingEntries(QuickAccessContents.java:243)
at org.eclipse.ui.internal.quickaccess.QuickAccessContents$2.modifyText(QuickAccessContents.java:372)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:179)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1058)
at org.eclipse.swt.widgets.Text.wmCommandChild(Text.java:2947)
at org.eclipse.swt.widgets.Control.WM_COMMAND(Control.java:4669)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4531)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4989)
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:2440)
at org.eclipse.swt.widgets.Text.callWindowProc(Text.java:260)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4623)
at org.eclipse.swt.widgets.Text.windowProc(Text.java:2570)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4976)
at org.eclipse.ui.internal.WorkbenchPage.busyShowView(WorkbenchPage.java:1166)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.java:3764)
at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage.java:3761)
at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage.java:3737)
at esc_configurator_tool.ExplorerView.makeAction(ExplorerView.java:74)
at esc_configurator_tool.ExplorerView.createPartControl(ExplorerView.java:63)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:129)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityView.createPartControl(CompatibilityView.java:155)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:300)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:857)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:837)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:111)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:318)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:240)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:161)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:141)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:889)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:623)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$6.run(PartRenderingEngine.java:511)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:496)
at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:74)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:725)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:696)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:690)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:675)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1042)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:98)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:639)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$1.handleEvent(PartRenderingEngine.java:126)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4687)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:187)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:81)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:57)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.impl.UIElementImpl.setToBeRendered(UIElementImpl.java:290)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:416)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:420)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:385)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:578)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:557)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:531)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:520)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:955)
at org.eclipse.ui.internal.WorkbenchPage.showPart(WorkbenchPage.java:1211)
at org.eclipse.ui.internal.WorkbenchPage.busyShowView(WorkbenchPage.java:1177)
at org.eclipse.ui.internal.quickaccess.ViewElement.execute(ViewElement.java:71)
at org.eclipse.ui.internal.quickaccess.SearchField$2.handleElementSelected(SearchField.java:153)
at org.eclipse.ui.internal.quickaccess.QuickAccessContents.handleSelection(QuickAccessContents.java:325)
at org.eclipse.ui.internal.quickaccess.QuickAccessContents.access$0(QuickAccessContents.java:315)
at org.eclipse.ui.internal.quickaccess.QuickAccessContents$6.mouseUp(QuickAccessContents.java:455)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:220)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
Previous Topic:trying to show File Diff in a TrayDialog
Next Topic:JFace TableViewer sorting in another thread
Current Time: Wed May 22 19:23:00 EDT 2013
Powered by FUDForum. Page generated in 0.01795 seconds
