Home » Eclipse Projects » BIRT » Exception generated when working with a Joint Data Set with Scripted Data Sources and Java Classes(Possible repeat of Bug 206054? (from 2007))
Exception generated when working with a Joint Data Set with Scripted Data Sources and Java Classes [message #986532] Tue, 20 November 2012 13:55 Go to next message
Chris Swingler is currently offline Chris Swingler
I've created a Scripted Data Source using an external Java class that works fine on its own, but does not when asked to be part of a Joint Data Set.
I'm skipping over the steps to reproduce, as it exactly follows this ancient BIRT bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=206054
The only peculiar thing that takes place is this. From the Edit Data Set window, Previewing works fine. If you click the list of Output Columns, it also appears fine. After clicking OK, though, you get "Script engine error: Type Error [JavaPackage <package name>] is not a function it is object.
Any ideas?
Thanks!
Re: Exception generated when working with a Joint Data Set with Scripted Data Sources and Java Class [message #986566 is a reply to message #986532] Tue, 20 November 2012 18:59 Go to previous messageGo to next message
Michael Williams is currently offline Michael Williams
If you drag the joint dataSet into your design window, to create a table, and preview, does it work? Can you attach your report?
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Re: Exception generated when working with a Joint Data Set with Scripted Data Sources and Java Class [message #986568 is a reply to message #986566] Tue, 20 November 2012 19:04 Go to previous messageGo to next message
Dragging it over does not work, and the little triangle to bring down the members of the data set doesn't work either.
Strangely, while troubleshooting this, I grabbed the example scripted data source from birt-exchange.org and tried it - that worked fine. I'll have to see if it's possible for me to post my report tomorrow when I get back into the office.
Re: Exception generated when working with a Joint Data Set with Scripted Data Sources and Java Class [message #986844 is a reply to message #986568] Wed, 21 November 2012 17:07 Go to previous messageGo to next message
Okay, after a bit more digging, I found that if I moved everything in the Data Source Open script to the Data Set Open, it works fine. If that's by design, i guess, let me know?
I'll have to see if there's more information I can dig up here next week. I'll follow up, and if prudent, file a bug report!
Thanks for your interest, and help, if I eventually do something in need of it Smile
Re: Exception generated when working with a Joint Data Set with Scripted Data Sources and Java Class [message #987522 is a reply to message #986844] Mon, 26 November 2012 18:19 Go to previous message
Yeah, I typically use the dataSet's Open script for connecting to data. Glad it's working now!
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Previous Topic:Your Feedback Is Needed To Plan the Next Eclipse BIRT Release
Next Topic:How Do I Hide certain detail and column areas in a crosstab?
Current Time: Fri May 24 11:57:26 EDT 2013
Powered by FUDForum. Page generated in 0.02212 seconds
