Home » Eclipse Projects » Virgo » Bundlor issue with blueprint
Bundlor issue with blueprint [message #986450] Tue, 20 November 2012 08:15 Go to next message
Rigas Grigoropoulos is currently offline Rigas Grigoropoulos
I am using Bundlor 1.1.2.RELEASE and trying to generate manifests for some blueprint projects.
Consider this simple test setup:
A project with only the following blueprint.xml file in resources/META-INF/ and no source or packages.
Note that the namespace links have been removed because unfortunately the forum does not allow to post links outside eclipse.org until I post 5 messages.
<blueprint xmlns="... blueprint namespace ..."
	xmlns:xsi="... XMLSchema namespace ..."
	xmlns:context="... spring context namespace... "
	xsi:schemaLocation="... blueprint and spring context namespaces ..."
	default-activation="eager">
	<context:component-scan base-package="net.test.impl"/>
	<context:annotation-config />
	<bean id="entityManagerFactory"
		class="org.springframework.orm.jpa.LocalContainerEntityManagerFactoryBean"/>
</blueprint>
Generating the manifest (either inside Eclipse or with a Maven build) creates this MANIFEST.MF:
Manifest-Version: 1.0
Tool: Bundlor 1.1.2.RELEASE
Import-Package: net.test.impl
which is missing the org.springframework.orm.jpa import.
Now changing only the first line of the blueprint.xml to the springframework namespace:
<blueprint xmlns="... springframework namespace ..."
</blueprint>
creates the correct manifest:
Import-Package: net.test.impl,org.springframework.orm.jpa
The same happens with every tag in my blueprint files, only the package from the "context:component-scan" tag is picked up.
Is there any workaround to this?
[Updated on: Tue, 20 November 2012 08:17]
Report message to a moderator
Re: Bundlor issue with blueprint [message #996620 is a reply to message #986450] Wed, 02 January 2013 09:38 Go to previous message
Glyn Normington is currently offline Glyn Normington
It appears that bundlor does not support the blueprint namespace, although it does support the Spring framework namespaces. You could raise an enhancment bugzilla for bundlor. Meanwhile, specify the necessary package imports in your bundlor template file.
Previous Topic:Virgo 3.6.0 Released
Next Topic:Problem installing hibernate library bundles
Current Time: Thu May 23 07:08:35 EDT 2013
Powered by FUDForum. Page generated in 0.01606 seconds
