Home » Eclipse Projects » Remote Application Platform (RAP) » RAP 2.0 tool issue
RAP 2.0 tool issue [message #986340] Tue, 20 November 2012 02:11 Go to next message
Avrajit Chatterjee is currently offline Avrajit Chatterjee
Member
Hi ,
I have Eclipse Juno(for RCP and RAP developers) and when I try to install Rap 2.0 M3 tool using update site http://download.eclipse.org/rt/rap/tools/2.0 I get the following error in Eclipse.
Cannot complete the install because of a conflicting dependency.
Software being installed: Rich Ajax Platform (RAP) Tools 2.0.0.20121109-1500 (org.eclipse.rap.tools.feature.feature.group 2.0.0.20121109-1500)
Software currently installed: Eclipse for RCP and RAP Developers 1.5.1.20120917-1257 (epp.package.rcp 1.5.1.20120917-1257)
Only one of the following can be installed at once:
RAP Templates Plug-in 1.5.0.20121106-1204 (org.eclipse.rap.ui.templates 1.5.0.20121106-1204)
RAP Templates Plug-in 1.5.0.20120613-1425 (org.eclipse.rap.ui.templates 1.5.0.20120613-1425)
RAP Templates Plug-in 1.5.1.20120917-1138 (org.eclipse.rap.ui.templates 1.5.1.20120917-1138)
Cannot satisfy dependency:
From: Eclipse for RCP and RAP Developers 1.5.1.20120917-1257 (epp.package.rcp 1.5.1.20120917-1257)
To: org.eclipse.epp.package.rcp.feature.feature.group [1.5.1.20120917-1257]
From: EPP RCP/RAP Feature 1.5.1.20120917-1257 (org.eclipse.epp.package.rcp.feature.feature.group 1.5.1.20120917-1257)
To: org.eclipse.rap.tools.feature.group 0.0.0
From: Rich Ajax Platform (RAP) Tools 2.0.0.20121109-1500 (org.eclipse.rap.tools.feature.feature.group 2.0.0.20121109-1500)
To: org.eclipse.rap.ui.templates [1.5.0.20121106-1204]
From: Rich Ajax Platform (RAP) Tools 1.5.0.20120613-1425 (org.eclipse.rap.tools.feature.group 1.5.0.20120613-1425)
To: org.eclipse.rap.ui.templates [1.5.0.20120613-1425]
From: Rich Ajax Platform (RAP) Tools 1.5.1.20120917-1138 (org.eclipse.rap.tools.feature.group 1.5.1.20120917-1138)
To: org.eclipse.rap.ui.templates [1.5.1.20120917-1138]
Re: RAP 2.0 tool issue [message #986345 is a reply to message #986340] Tue, 20 November 2012 02:53 Go to previous messageGo to next message
Ivan Furnadjiev is currently offline Ivan Furnadjiev
this is a know issue with the "Eclipse for RCP and RAP developers"
package and the latest RAP 2.0 Tools. See:
391336: [Tools] Failed to install latest nigthly from the repo
https://bugs.eclipse.org/bugs/show_bug.cgi?id=391336
We didn't manage to fix it for M3, but definitely will be fixed in M4.
I'm sorry for the inconvenience.
Best,
Ivan
On 11/20/2012 9:11 AM, Avrajit Chatterjee wrote:
> Hi ,
> in Eclipse.
> Only one of the following can be installed at once: RAP Templates
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: RAP 2.0 tool issue [message #986355 is a reply to message #986345] Tue, 20 November 2012 03:34 Go to previous messageGo to next message
Member
Thanks Ivan, I checkout some workarounds for these kind of issues but didnt want to spent any time to fix it by updating feature.xml and context.xml etc.
Instead I got Eclipse Classic Juno and installed RAP 2.0 M3 tool and its working for me.
Re: RAP 2.0 tool issue [message #989511 is a reply to message #986355] Thu, 06 December 2012 09:44 Go to previous messageGo to next message
Markus Knauer is currently offline Markus Knauer
Member
While I am trying to implement a solution for this problem, I tested different scenarios.
If you are starting with any EPP package that does *not* contain the RAP Tools, e.g. the Classic/SDK packages
eclipse-rcp-juno-SR1-linux-gtk-x86_64.tar.gz
eclipse-rcp-kepler-M3-linux-gtk-x86_64.tar.gz
you should be able to install RAP Tools 2.0 from http://download.eclipse.org/rt/rap/tools/2.0/ without any problems.
The Kepler M3 RCP/RAP package (eclipse-rcp-kepler-M3-linux-gtk-x86_64.tar.gz) from http://www.eclipse.org/downloads/index-developer.php already contains the RAP Tools 2.0 M3 and can be upgraded safely to the latest and greatest RAP nightly build.
The only package that does not work with RAP Tools 2.0 M3 is the Juno RCP/RAP package (and every package that had RAP Tools 1.5 installed manually). In this case you will run into dependency errors caused by singletons. Moreover you will run into additional problems if you try to install the latest nightly build. It *is* possible to install the new RAP Tools nightly builds into the Juno RCP/RAP package, but you will end up with a cluttered UI and even more problems. Be warned!
Re: RAP 2.0 tool issue [message #989969 is a reply to message #989511] Mon, 10 December 2012 05:11 Go to previous message
Member
This should be solved now with the latest nightly builds of the RAP Tools.
You can test it with the nightly build p2 repository at http://download.eclipse.org/rt/rap/nightly/tooling/.
Further information about the solution can be found in Bugzilla: https://bugs.eclipse.org/bugs/show_bug.cgi?id=391336
Markus
Previous Topic:TableColumn and Table Fonts
Next Topic: JFace TableViewer/Table setitemcount() slow
Current Time: Fri May 24 12:19:02 EDT 2013
Powered by FUDForum. Page generated in 0.01668 seconds
