Home » Modeling » ATL » Implied linking in Refining mode(Linking model element by their generated target elements)
Implied linking in Refining mode [message #986193] Mon, 19 November 2012 07:00 Go to next message
Jörn Guy  Süss is currently offline Jörn Guy Süss
Member
I have a refining transformation that adds elements based on a DTD model to a base UML model. I would like to use the declarative base pattern shown below, that has been taken from the standard manual. My code is in the second snippet.
rule Case2_R1 {
	from
		i : MM_A!ClassA
	to
		o_1 : MM_B!Class1 (
			linkToClass2 <- i.linkToClassB
rule Case2_R2 {
 	from
		i : MM_A!ClassB
	to
		o_1 : MM_B!Class2 (
The code below is only allowed to run if 'inter-model relations are enabled'. If that is enabled, it fails with a typecast:
org.eclipse.wst.dtd.core.internal.emf.impl.DTDFileImpl cannot be cast to net.jgsuess.uml14.foundation.core.Namespace
The intention of the code is that a UML class generated from a DTD element should link to the UML package that corresponds to the DTD elements' DTD file.
I assume I am doing something wrong in setting up the matching.
-- @atlcompiler atl2010
-- @nsURI UML=http://jgsuess.net/uml14
-- @nsURI DTD=DTD.xmi
module transform;
create OUT: UML refining IN: UML, dtd: DTD;
rule File2Package {
	from
		s: DTD!DTDFile
	to
		t: DTD!DTDFile,
		p: UML!Package (
			name <- 'dtdfile'
rule Element2Class {
	from
		s: DTD!DTDElement
	to
		t: DTD!DTDElement,
		c: UML!Class (
			namespace <- s.DTDFile,
			name <- s.name
[Updated on: Mon, 19 November 2012 07:04]
Report message to a moderator
Re: Implied linking in Refining mode [message #986194 is a reply to message #986193] Mon, 19 November 2012 07:17 Go to previous message
Member
Disregard my message above. For those looking, underneath is the solution:
  • Inter-model relations have to be on
  • You have to use thisModule.resolveTemp to obtain the secondary element
The thisModule.resolveTemp is necessary, because in this case the interesting elements are created as side-effects.
module transform;
rule File2Package {
	from
		s: DTD!DTDFile
	to
		t: DTD!DTDFile,
		p: UML!Package (
			name <- 'dtdfile'
	from
		s: DTD!DTDElement
	to
		t: DTD!DTDElement,
		c: UML!Class (
			namespace <- thisModule.resolveTemp(s.DTDFile, 'p'),
			name <- s.name
Previous Topic:How to mix in model elements in refining mode
Next Topic:ATL transformation programming in java code
Current Time: Fri May 24 03:21:22 EDT 2013
Powered by FUDForum. Page generated in 0.01500 seconds
