Home » Modeling » Papyrus » Exported class diagrams missing text
Exported class diagrams missing text [message #986192] Mon, 19 November 2012 06:49 Go to next message
Andy Key is currently offline Andy Key
I have a few class diagrams in a model that I would like to export as an image. When I try either clicking on the model and the "Export all diagrams..." option, or right-clicking inside a diagram and "File -> Save as image file", the images are generated. However, most of the labels in the classes are missing, ie. the properties and operations are not present in the exported diagrams - except of course for one particular property. At times, not even the class names are present, just the applied stereotypes. No exceptions are written to .metadata/.log when running the export. It seems to me that it is attempting to render the properties, and runs into an exception which is caught and ignored, without being logged (just a theory of course).
Has anyone else seen this?
index.php/fa/12437/0/
Re: Exported class diagrams missing text [message #986216 is a reply to message #986192] Mon, 19 November 2012 08:49 Go to previous messageGo to next message
Camille Letavernier is currently offline Camille Letavernier
It works correctly for me. What version of Papyrus do you use ?
Camille
Re: Exported class diagrams missing text [message #986218 is a reply to message #986192] Mon, 19 November 2012 08:49 Go to previous messageGo to next message
Christian W. Damus is currently offline Christian W. Damus
Hi, Andy,
What file format are you exporting to? And on what platform?
I've found that GMF can't reliably export PNG on Mac OS X. Text is one
of the problems. I use the JPG option exclusively on Mac.
Christian
> <image>
Re: Exported class diagrams missing text [message #986362 is a reply to message #986216] Tue, 20 November 2012 04:00 Go to previous message
@Camille:
I am using the latest release of Topcased, 5.2.0, which has Papyrus 0.8.2.v201204031124, at least according to the eclipse installation details page. Running Ubuntu 12.04 64-bit, OpenJdk 1.6.0_24-b24. Was trying to save the diagrams as PNG.
@Christian:
It appears that PNG output on 64-bit Ubuntu is also borked. JPEG exported correctly with all text. Thanks for the tip!
Previous Topic:My question to specialist of MARTE
Next Topic:Peut-on faire du reverse d'un programme Java avec Papyrus ?
Current Time: Sat May 25 22:49:17 EDT 2013
Powered by FUDForum. Page generated in 0.04545 seconds
