Home » Modeling » Papyrus » how reverse engineering ?
how reverse engineering ? [message #892062] Tue, 26 June 2012 23:54 Go to next message
PHIL C is currently offline PHIL C
It seems Papyrus has reverse engineering on
- org.eclipse.papyrus.java.reverse
- org.eclipse.papyrus.java.reverse.ui
How find it and install it into my Eclipse INDIGO for reverse my code ?
Philippe
Re: how reverse engineering ? [message #895726 is a reply to message #892062] Sun, 15 July 2012 08:11 Go to previous messageGo to next message
I could not found reverse plugin with http://www.eclipse.org/forums/index.php/t/149226/
Philippe
Re: how reverse engineering ? [message #930533 is a reply to message #892062] Tue, 02 October 2012 07:58 Go to previous messageGo to next message
Cedric Dumoulin is currently offline Cedric Dumoulin
Member
Sorry for the so long delay.
Maybe this can help other users.
Yes, it is possible to reverse Java code into Papyrus. The plugins
are in the trunk:
org.eclipse.mdt.papyrus/trunk/extraplugins/java/org.eclipse.papyrus.java.reverse
org.eclipse.mdt.papyrus/trunk/extraplugins/java/org.eclipse.papyrus.java.reverse.ui
There is a compiled version here:
http://www.lifl.fr/~dumoulin/papyrus-update/org.eclipse.papyrus.java-updatesite/
Hope this help,
Cedric
PHIL C a écrit :
> Regards
> Philippe
Re: how reverse engineering ? [message #952117 is a reply to message #930533] Sun, 21 October 2012 02:58 Go to previous messageGo to next message
Ok
Merci Cedric, je regarde cela demain
Philippe
Re: how reverse engineering ? [message #956247 is a reply to message #952117] Wed, 24 October 2012 06:55 Go to previous messageGo to next message
Hi Cedric,
How could i activate reverse function from Eclipse ?
Philippe
Re: how reverse engineering ? [message #986178 is a reply to message #956247] Mon, 19 November 2012 05:28 Go to previous messageGo to next message
Fred Pied is currently offline Fred Pied
Bonjour,
J'ai réussi à installer le plugin de Cédric également mais je n'arrive pas à faire du reverse engineering pour générer mes classes à partir du code Java.
Est ce que vous avez pu avancer sur le sujet ?
Merci
fred
Re: how reverse engineering ? [message #994656 is a reply to message #986178] Thu, 27 December 2012 18:53 Go to previous messageGo to next message
Ian C is currently offline Ian C
Hi Cedric,
Juno Support?
Is this plug-in meant to work for Eclipse Juno?
Sincerely,
Ian
Re: how reverse engineering ? [message #1006124 is a reply to message #986178] Wed, 30 January 2013 00:34 Go to previous message
Bonjour,
Je n'ai pas avancé sur le sujet de mon coté, dans la vue Java sous Juno, je n'arrive pas a obtenir l'icone et le menu Papyrus -> Java -> Java Reverse.
Le plugin de Cedric est poutant bien marque comme installé !
Et vous ???
Cordialement
Philippe
Previous Topic:Message Arguments
Next Topic:Best Way to Import Existing UML model into Papyrus
Current Time: Mon May 20 10:24:29 EDT 2013
Powered by FUDForum. Page generated in 0.02068 seconds
