| Cannot see JSF palette or JSF project template in RAD 8.5 [message #985454] |
Thu, 15 November 2012 07:06  |
Haim Schneider Messages: 3 Registered: November 2012 |
Junior Member |
I installed RAD 8.5 and I'm trying to create a JSF application, but things are not working as documented. When I create a new Web Project, I do not see "Java Server Faces" template in the list of project templates. The only templates I see are "Dojo Toolkit", "Rest services" and "Simple". Instead, I created a Dynamic web project, and selected "Java Server Faces v2.0 project" from the list of configuration. The project was indeed created with JSF settings in web.xml and faces-config.xml, but when I create a JSP page, I cannot see the JSF editing tools. There is no JSF palette in the palettes pane. I verified that the Java Server Faces facet is selected in the Project Facets. Anything else I need to do to get the JSF project template and the JSF palette?
FUDForum. Page generated in 0.02160 seconds
