| Re: Integrate external application in SWT application [message #986008 is a reply to message #985983] |
Sat, 17 November 2012 06:28  |
Thomas Schindl Messages: 4462 Registered: July 2009 |
Hm - IIRC on windows we once used the native handle of the composite and
passed that to the native application, but I can't find the code anymore :-(
Tom
Am 16.11.12 23:03, schrieb Grant Gayed:
> Is the application that you want to embed written as either an Active X
> control or an OLE Document? This is something that an app whose intent
> is to be embeddable must do explicitly, and most do not do this. There
> is not an alternate way to integrate a native application in SWT. From
> SWT you can use the Program class to launch an external application, but
> I don't know if this would make sense in your context or not.
> Grant
> On 11/7/2012 1:09 AM, Ankit Agarwal wrote:
>> I understood how to integrate the application as described in the
>> following links
>> http://www.eclipse.org/articles/article.php?file=Article-ActivexSupportInSwt/index.html
>> and http://www.ibm.com/developerworks/opensource/library/os-activex/# ,
>> but the problem now is that it requires a program ID. i tried to find
>> the program Id of the application from Windows registry but it seems
>> that the application does not have a program ID. IS there any alternate
>> approach by which i can integrate or any way by which i can assign a
>> program ID to the application
FUDForum. Page generated in 0.01593 seconds
