Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Texo - implementing an interface(How to generate jpa code for the model which implements an interface)
Texo - implementing an interface [message #985778] Fri, 16 November 2012 02:06 Go to next message
Pradeep Badiger is currently offline Pradeep Badiger
Member
How do we generate JPA code using texo for the models which implement interfaces?
Pradeep V.B.
Re: Texo - implementing an interface [message #985867 is a reply to message #985778] Fri, 16 November 2012 08:49 Go to previous messageGo to next message
Martin Taal is currently offline Martin Taal
Hi Pradeep,
The epackage annotation model has an option to generate interfaces. Also if an eclass is set to be an interface then it
is generated as an interface.
Btw, afaik JPA and interfaces don't go well together.
gr. Martin
On 11/16/2012 08:06 AM, Pradeep Badiger wrote:
> Pradeep V.B.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: Texo - implementing an interface [message #985875 is a reply to message #985778] Fri, 16 November 2012 09:18 Go to previous messageGo to next message
Member
Hi Martin,
I was able to create an interface. Attached is the sample ecore file which has an interface and a concrete class implementing this interface. When i tried generating the jpa/model code, i was able to see only the interface and not the concrete class.
Is there anything that i am missing here?
thanks,
Pradeep V.B.
Re: Texo - implementing an interface [message #985886 is a reply to message #985875] Fri, 16 November 2012 09:56 Go to previous messageGo to next message
Member
Ahh, silly mistake.. I added the ESuper Type as the interface and now it generates both classes. But i dont see the operations generated. Is that something missing?
Re: Texo - implementing an interface [message #985893 is a reply to message #985886] Fri, 16 November 2012 10:21 Go to previous message
Hi Pradeep,
Operations are currently not supported (i.e. not generated) by Texo. There is no obstacle to implement it other than
time/resources though...
gr. Martin
The Netherlands
Previous Topic:[Teneo] Use objects in a query later on
Next Topic:Call EMF Compare
Current Time: Thu May 23 20:00:51 EDT 2013
Powered by FUDForum. Page generated in 0.02015 seconds
