| Problem in loading meta Model [message #985830] |
Fri, 16 November 2012 05:05  |
dorraaaa Z Messages: 22 Registered: June 2012 |
Junior Member |
Normally, the meta model should be loaded at first , for enabling the Sample Ecore Model Editor to provide a tree structure representation of the Ecore model
but when i do a right click to select this option at the Meta Model, it is not visible for me
what is the problem? i have installed other version of Eclipse but i doesn't work
CAN YOU HELP ME PLEAAASE
I haven't enought time
Thank u
| Re: Problem in loading meta Model [message #985841 is a reply to message #985830] |
Fri, 16 November 2012 05:41  |
Hugo Bruneliere Messages: 467 Registered: July 2009 |
For the "Register Metamodel" action to be available from a right-click on an Ecore file, you need to use the Project Explorer in the ATL perspective.
Hugo
Hugo Bruneliere - R&D Engineer
AtlanMod research team (Inria, EMN & LINA)
Ecole des Mines de Nantes
Nantes - France
FUDForum. Page generated in 0.01574 seconds
