Home » Eclipse Projects » Eclipse 4 » What is the InputURI for in e4 InputParts?
What is the InputURI for in e4 InputParts? [message #985816] Fri, 16 November 2012 04:34 Go to next message
Alex Kipling is currently offline Alex Kipling
I found out, that InputParts are Parts with a "dirtyable" Flag?
What is the InputURI intended to be used for in InputParts?
Re: What is the InputURI for in e4 InputParts? [message #985820 is a reply to message #985816] Fri, 16 November 2012 04:45 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas Schindl
MPart also has a dirty because they both derive from MDirtyable.
InputParts are planned to be used when we natively implement editors in
e4, so it will point to a resource e.g.
resource://myproject/build.properties, mydb://person_table?p_id=10
Tom
Am 16.11.12 10:34, schrieb Alex Kipling:
Re: What is the InputURI for in e4 InputParts? [message #985826 is a reply to message #985820] Fri, 16 November 2012 04:56 Go to previous messageGo to next message
So InputParts are used to implement editors, which are dirtyable?
And InputURI points to the resource, where the Editor data will be stored? (e.g a database-table pointer mydb://person_table?p_id=10)
Re: What is the InputURI for in e4 InputParts? [message #985832 is a reply to message #985826] Fri, 16 November 2012 05:07 Go to previous message
Right but like I said currently we have not implemented native editor
support yet, what we miss is an MEditorDescriptor to replace the 3.x
extension point.
I still have it on my to do list for 4.3 and really hope I manage to
come up with a proposal but that heavily depends on the time I can spend
on it and at the moment other things are more important to me.
I'm not sure on your dirtyable comment because MInputPart inherits from
MPart which mixes in MDirtyable, so any part in the system is dirtyable ;-)
Tom
Am 16.11.12 10:56, schrieb Alex Kipling:
> So InputParts are used to implement editors, which are dirtyable? And
Previous Topic:What is the difference between Area and PartSash Containers in e4?
Next Topic:Window created by dragging Tab out from Workbench - is not resizable!
Current Time: Fri May 24 14:22:42 EDT 2013
Powered by FUDForum. Page generated in 0.06494 seconds
