| Re: Getting started with non EMF Domain Models, need an example [message #945725 is a reply to message #900976] |
Mon, 15 October 2012 11:24   |
Using the attached project from this thread I am trying to get the properties view be filled with the properties of the current selection in the diagram but I am somehow unable to get it working. Tried to implement IPropertySource within the domain model objects but that doesn't seem to be enough. Any idea what I am missing here / what is required to get the properties view filled with the properties of the currently selected figure in the diagram?
thanks in advance,
Lars
| Re: Getting started with non EMF Domain Models, need an example [message #974965 is a reply to message #947592] |
Wed, 07 November 2012 08:29   |
Saniya Mirajkar Messages: 30 Registered: August 2012 |
Member |
Hi ,
I use the example in this post as reference for creating Graphiti diagrams.The latest code that is posted on this thread works for me in version 0.9.1 perfectly.
I have recently migrated my code from version 0.8.2 to 0.9.1 with which my code does not seem to work.I am doing nothing different apart from replacing the code with appropriate API of 0.9.1.
I use the following code in my Action class to open the editor:
IWorkbenchPage page = PlatformUI.getWorkbench()
.getActiveWorkbenchWindow().getActivePage();
final IEditorInput editorInput = RepositoryUtils.getEditorInput();
final DiagramTypeProvider dtyProvider = (DiagramTypeProvider)
ExtensionManager.getSingleton().createDiagramTypeProvider(
DIAGRAM_TYPE_PROVIDER_ID);
final Diagram diagram = Graphiti.getPeCreateService()
.createDiagram(DIAGRAM_TYPE, "Test Diagram",
false);
final TestDiagramEditor diagramEditor = new TestDiagramEditor();
dtyProvider.init(diagram, diagramEditor);
page.openEditor(editorInput,TestDiagramEditor.DIAGRAM_EDITOR_ID);
And the code for getEditorInput() of RepositoryUtils is as follows:
public static IEditorInput getEditorInput() throws Exception {
private final static String DIAGRAM_NAME = "NonEmf.diagramNonEmf";
String diagramFileName = "";
String dataFileName = "";
final IWorkspaceRoot root = ResourcesPlugin.getWorkspace().getRoot();
IPath path = root.getLocation();
dataFileName = path + "/files/NonEmf.xml";
diagramFileName = path + "/files/NonEmf.diagramNonEmf";
final IProject project = root.getProject("files");
if (!project.exists()) {
project.create(null);
if (!(project.isOpen())) {
project.open(null);
IFile diagramFile = project.getFile(DIAGRAM_NAME);
URI emfURI = URI.createURI(diagramFile.toString());
TestDiagramEditorInput result = null;
if (emfURI != null) {
URI diagramUri = emfURI.appendFragment("/0");
result = new TestDiagramEditorInput(diagramUri, null);
result.setDataFileName(dataFileName);
result.setDiagramFileName(diagramFileName);
return result;
The same thing used to work for me for version 0.8.2. Now I do not get any error but the diagram file is not created and when I open the editor since there is no diagram file under the given path following message is shown on editor :"No Diagram found for URI 'L/files/NonEmf.diagramNonEmf#/0"
[Updated on: Wed, 07 November 2012 09:17] Report message to a moderator
| Re: Getting started with non EMF Domain Models, need an example [message #985568 is a reply to message #983820] |
Thu, 15 November 2012 08:57   |
Nikolai Raitsev Messages: 100 Registered: July 2009 |
Hi Hemlata,
I am happy that my example has helped you.
In fact, the code from the example should be migrated to Graphiti version 0.9.x.
In the Github version of my example (https://github.com/kumarunster/phirea.public/tree/master/test.graphiti.nonemf) you can see the current state of the example, and it runs on 0.9 version of Graphiti, but unfortunately I cannot exactly say (on the fly), what you should change...
In the whole example I'm trying to show, how is it possible to use Graphiti based editors without EMF lock-in of the domain model. If you look at ApplicationWorkbenchWindowAdvisor you have a Tip, how to get the right EditorInput for your Graphiti-Editor.
About my case: In my application I have a datamodel, that is stored in a database and a lot of graphiti-xml-files, that are stored in a database too. The graphiti-xml's are all created programatically from some template-files, and all the referenced objects in that diagram files are drag-n-dropped from my "Repository". That files are copied, if a EditorInput is produced, in a Temp-Folder from my Application every time the new User-Session is started and a diagram is requested. On Save-Actions they are stored in the DB as BLOB.
If you have any questions, so feel free to ask me and look to the github version of my example!
Nikolai
| Re: Getting started with non EMF Domain Models, need an example [message #985772 is a reply to message #985568] |
Fri, 16 November 2012 01:16   |
Member |
Hi Nikolai,
Thanks for that valuable info.
I use the github version of your example which works well with Graphiti 0.9.1 as well.
I do get EditorInput for my Graphiti-Editor the way you get it in ApplicationWorkbenchWindowAdvisor.
In my case I do not want to persist graphiti related info in the database.Right now I am just trying to add the pictogram representation of the domain object to the diagram editor with version 0.9.1
I try to create my own Graphiti diagram as follows:
IEditorInput input = RepositoryUtils.getEditorInput();
// Create the pictogram for selected Functional Variable
.createDiagram(DIAGRAM_TYPE, sourceVariable_.getName(),
false);
DiagramEditor editor = new DiagramEditor();
final DiagramTypeProvider dtyProvider = (DiagramTypeProvider) ExtensionManager
dtyProvider.init(diagram, editor);
page.openEditor(input, DiagramEditor.DIAGRAM_EDITOR_ID);
With this blank graphical editor opens up.And now I try to add the buisness object to this diaram using following stuff:
AddContext addContext = new AddContext();
addContext.setNewObject(object);
addContext.setLocation(200, 300);
addContext.setSize(100, 200);
addContext.setTargetContainer(diagram);
DiagramFeatureProvider fp = (DiagramFeatureProvider) dtyProvider
.getFeatureProvider();
AddFunctionalVariableFeature feature = (AddFunctionalVariableFeature)
dtyProvider.getFeatureProvider().getAddFeature(addContext);
dtyProvider.getFeatureProvider().addIfPossible(addContext);
When using this ,internally it gives Nullpointer exception for getEditDomain() in addIfPossible method as follows:
org.eclipse.core.runtime.AssertionFailedException: null argument:
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:85)
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:73)
at org.eclipse.graphiti.ui.editor.DiagramEditor.executeFeature(DiagramEditor.java:1946)
at org.eclipse.graphiti.features.impl.AbstractFeatureProvider.addIfPossible(AbstractFeatureProvider.java:331)
I suppose that is because my editor is not getting initialised properly.
On debugging I see that my Editor has no TransactionalEditingDomain.With version 0.8.2 I created my own TransactionalEditingDomain and passed that to constructor of DiagramEditor. But in version 0.9 there is no constructor which accepts TransactionalEditingDomain.
I am now stuck at point as how to add the pictogram on the diagram with the new version of Graphiti.
| Re: Getting started with non EMF Domain Models, need an example [message #985810 is a reply to message #985772] |
Fri, 16 November 2012 04:07  |
Michael Wenz Messages: 1272 Registered: July 2009 Location: Walldorf, Germany |
Hemlata,
in case the editing domain is the issue, that is indeed changed between 0.8
and 0.9: instead of passing a domain into the input (FWIW: which caused the
input object to be not as light-weight as it should be - that's the reason
why we removed it) you should now be able to create a special editing domain
in your own subclass of DefaultUpdateBehavior (override
DiagramEditor.createUpdateBehavior to hook in your own instance of that
class). DefaultUpdateBehavior offers a method createEditingDomain you could
override.
HTH,
Michael
FUDForum. Page generated in 0.02165 seconds
