Home » Modeling » TMF (Xtext) » Running the Xtext machinery outside the builder
| Running the Xtext machinery outside the builder [message #985515] |
Thu, 15 November 2012 08:09  |
Vlad Dumitrescu Messages: 313 Registered: July 2009 Location: Gothenburg |
Hi!
I want to try to improve the experience for large projects by disabling the Xtext builder and instead have the builder feed the resource change events to a queue, which a background thread can use as input and feed them to the Xtext indexer. This also provides a place where to hook in pre-built indexes, for libraries and such.
We are accepting that while this isn't finished, the IDE functionality will be incomplete.
My question is: is there any technical detail in Xtext that might prevent this from working?
best regards,
Vlad
| Re: Running the Xtext machinery outside the builder [message #985735 is a reply to message #985515] |
Thu, 15 November 2012 16:22   |
Jan Kohnlein Messages: 572 Registered: July 2009 |
But the builder is already running in background and queueing/clustering
resources to be build, isn't it?
Also note that a whole bunch of services are relying of the index to be
uptodate and consistent, e.g. linking, refactoring, find references...
I'd hook in pre-build indexes with a customized IGlobalScopeProvider.
Am 15.11.12 14:09, schrieb Vlad Dumitrescu:
> Hi!
> will be incomplete.
> best regards,
> Vlad
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
| Re: Running the Xtext machinery outside the builder [message #985740 is a reply to message #985735] |
Thu, 15 November 2012 16:51   |
Hi Jan,
Jan Kohnlein wrote on Thu, 15 November 2012 22:22But the builder is already running in background and queueing/clustering
Yes, it does that, but in the meanwhile the workspace is locked and then the user can't do very much. It is important in may case, since the build takes so long.
Quote:Also note that a whole bunch of services are relying of the index to be
My hope is that they only need the index to be updated and consistent if they are to provide correct information. If the user is aware that while building, there might be inconsistent info/behaviour, then I believe it can mitigate the pain. Operations like refactoring or quickfixes should be disabled.
That said, I tried to put in practice this idea and it's not easy to get the right context, having Guice and OSGi to play nice... Maybe it won't be possible to do it, but I feel I have to try, as I am running out of options.
Even if I can convince you (the Itemis team) to work some magic (for the community or as a commercial service), I begin to think that it still won't be something done in a few weeks or so.
Thanks!
best regards,
Vlad
[Updated on: Thu, 15 November 2012 16:51] Report message to a moderator
| Re: Running the Xtext machinery outside the builder [message #985743 is a reply to message #985740] |
Thu, 15 November 2012 17:03   |
Have you done some profiling on what exactly takes so long? If it is
really the indexing, maybe you can implement a better strategy.
Am 15.11.12 22:51, schrieb Vlad Dumitrescu:
> Hi Jan,
>> queueing/clustering resources to be build, isn't it?
> [/quote]Also note that a whole bunch of services are relying of the
> index to be uptodate and consistent, e.g. linking, refactoring, find
> references... [/quote]
> be disabled.
> options.
> Thanks!
> best regards,
> Vlad
| Re: Running the Xtext machinery outside the builder [message #985935 is a reply to message #985747] |
Fri, 16 November 2012 13:01   |
If there are really no more cross-references, linking should be a no-op.
And the Antlr parser is usually very fast.
Is it an Xbase language? Linking can be seriously speeded up by adding
some explicit types, especially to closure parameters. Or with the
completely overhauled typesystem implementation that is planned for the
next release early next year.
If validation is slow, it's worth looking at closer, as you can really
write validation rules such that complexity explodes.
Am 15.11.12 23:49, schrieb Vlad Dumitrescu:
> Jan Kohnlein wrote on Thu, 15 November 2012 23:03
> Yes, I profiled it. Maybe I'm using the wrong words here. By 'indexing'
> I refer to validation and linking. I don't have any validation other
> than the default one, but the linking is what takes time. From what I
> can see, it is heavier than linear with the number of files/links.
> I also tried to remove all cross-references from the grammar and of
> course it's faster, but it's still too slow for the large projects.
> That's why I thought about the "run it outside the builder" idea.
> Thanks for your help!
> best regards,
> Vlad
| Re: Running the Xtext machinery outside the builder [message #987124 is a reply to message #985967] |
Fri, 23 November 2012 10:56   |
Knut Wannheden Messages: 283 Registered: July 2009 |
Hi Vlad,
I think you will probably find that this won't work well. I think there
is just too much that can go wrong. E.g. what happens if the user edits
a file that was already built or even deletes a file which the builder
has queued, etc.
I think you are then probably better of by investigating the efforts
that were made on tickets
https://bugs.eclipse.org/bugs/show_bug.cgi?id=358714 and
https://bugs.eclipse.org/bugs/show_bug.cgi?id=359824. Note that these
are certainly not for the faint-hearted as they will require some
fiddling (overriding Guice module for shared state).
--knut
On 11/16/12 10:19 PM, Vlad Dumitrescu wrote:
> Hi Jan,
> The language is Erlang, so it has nothing to do with Xbase. This also
> explains why there is already a huge base of code that needs to be
> parsed and analyzed.
> In a project the size that I need to handle, all jobs that need to go
> through all the files will be slow (for an operation in an IDE). This is
> unavoidable. What makes it unacceptable for our users is that the
> project is locked and no changes can be saved. If this part is solved,
> it will buy us some time to optimize the linking and validation.
> I've spent the day investigating my idea for wrapping the Xtext builder
> in a non-locking job, but it hasn't been designed with this use case in
> mind and it's not as easy as I had hoped :)
> best regards,
> Vlad
| Re: Running the Xtext machinery outside the builder [message #987381 is a reply to message #987124] |
Mon, 26 November 2012 06:30  |
Thanks, Knut.
What I hope would happen if there is an edit while the index is built is that there will be some transient errors, that will go away when the notification for the new change is processed.
Realistically, in the ~15 minutes at the start of his session (when xtext will do the heavy build) a user will probably checkout a couple of files from VCS and make changes to a couple more. That should not make Xtext utterly confused, in my mind.
regards,
Vlad
Current Time: Sat May 25 23:17:53 EDT 2013
Powered by FUDForum. Page generated in 0.02428 seconds
