Home » Eclipse Projects » Requirements Modeling Framework  » xmi serialization of reqif model
xmi serialization of reqif model [message #984224] Wed, 14 November 2012 09:11 Go to next message
David Villa is currently offline David Villa
Hello guys, I would like to serialize my reqif model as xmi, instead of xml. Do you provide a feature that can help me? Thank you!
Re: xmi serialization of reqif model [message #985633 is a reply to message #984224] Thu, 15 November 2012 09:56 Go to previous message
Michael Jastram is currently offline Michael Jastram
Member
Hi David,
As XMI is the default persistence format for EMF, that should be easy. I haven't tried it, but I guess it should be sufficient to register EMF's native persister with a file extension of your choice, e.g. .xmi. Then you can use "Save as..." to convert between xmi and reqif.
Hope this helps.
- Michael
Previous Topic:Links to other documents
Next Topic:RMF Standalone
Current Time: Tue Jun 18 00:34:10 EDT 2013
Powered by FUDForum. Page generated in 0.01411 seconds
