Marius Zadara Messages: 3 Registered: November 2012 Location: Romania
Hello everybody!
I wrote a custom connector, but I have a problem: althought the query is created and the tasks are added into it at sync moment, after I restart the Eclipse, all the tasks have been moved into the "unmatched" container.
First I thought that it was due to the fact that I launched the product from the Eclise, but the same behavior happens also when the feature is installed into a "clean" workspace.
No suggestion at all ? Hasn't anyone faced the problem, found the cause and can point me in the correct direction ?
If I'm using categories, all ok, but I lose the query advantage.
Solution: the RepositoryQuery class should NOT be extended, otherwise an warning will be displayed and the issues attached to the query will not be contained into the query but moved into the 'unmatched' category.
I please the admins to close the topic since no further assistance is needed on this topic.
Thanks.
