Home » Eclipse Projects » Eclipse 4 » Eclipse complain about working code
Eclipse complain about working code [message #985381] Thu, 15 November 2012 05:56 Go to next message
Sverre Moe is currently offline Sverre Moe
Have the following C++ code which eclipse complains about. Running make gives out no error on this.
#include <unordered_map>
std::unordered_map<std::string, status> results;
std::unordered_map<std::string, status>::iterator result_iterator;
Symbol 'unordered_map' could not be resolved
Same goes for any functions used with this unordered_map.
This is not the only one eclipse have a problem with.
#include <sigc++/signal.h>
#include <sigc++/connection.h>
sigc::signal<void, bool> _signal_connected;
sigc::connection conn_ml;
Eclipse have no problem with the code for sigc::signal, but complains about sigc::connection. Make goes fine and running the application also fine.
I hate having eclipse showing multiple errors where there is none. So how can I get eclipse to see that this is correct?
Re: Eclipse complain about working code [message #985391 is a reply to message #985381] Thu, 15 November 2012 06:01 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas Schindl
Please ask at the cdt forum.
Tom
Am 15.11.12 11:56, schrieb Sverre Moe:
> Quote:
> fine.
Re: Eclipse complain about working code [message #985392 is a reply to message #985391] Thu, 15 November 2012 06:08 Go to previous messageGo to next message
I thought I did... Sorry.
Should I repost or could a moderator move this one?
Re: Eclipse complain about working code [message #985414 is a reply to message #985392] Thu, 15 November 2012 06:20 Go to previous message
Repost please.
Am 15.11.12 12:08, schrieb Sverre Moe:
Previous Topic:No MBasicPackage Interface
Next Topic:Making a fixed perspective in an e4 model?
Current Time: Fri May 24 20:30:36 EDT 2013
Powered by FUDForum. Page generated in 0.03288 seconds
