| Removing Syntax Errors indicated by Eclipse [message #985353] |
Thu, 15 November 2012 05:33  |
Andreas Unwichtig Messages: 1 Registered: November 2012 |
Junior Member |
I'm working with Eclipse Juno on Ubuntu 12.04.
I have the problem that eclipse erroneously indicates syntactical errors when i use an assert statement oder checking whether a pointer is NULL. So Eclipse doesn't know assert and NULL.
Is it possible to teach eclipse that these expressions are correct or simply to disable the syntax check for these keywords?
Thanks for you help!
regards
FUDForum. Page generated in 0.01907 seconds
