Home » Modeling » EMF » [XSD2Ecore] is removing removing underscore from EEnumLiteral name and not setting literal
[XSD2Ecore] is removing removing underscore from EEnumLiteral name and not setting literal [message #984678] Wed, 14 November 2012 17:21 Go to next message
David Rees is currently offline David Rees
Member
I'm running into a name mapping problem where XSD2Ecore is mapping an Restriction with Enumeration Facets to an EENum. Each enumeration value has an underscore, but the corresponding EEnumLiteral's name has the underscore removed and the it's literal is not properly set to original value either. I'll add I don't think removing the underscore should be required to make it a valid Java name anyway.
Is this a bug or am I missing an option somewhere?
dave
Here is the XSD snippet:
    <xsd:simpleType name="DATA-TYPE">
        <xsd:restriction base="xsd:string">
            <xsd:enumeration value="A_INT32"/>
            <xsd:enumeration value="A_UINT32"/>
            <xsd:enumeration value="A_FLOAT32"/>
            <xsd:enumeration value="A_FLOAT64"/>
            <xsd:enumeration value="A_ASCIISTRING"/>
            <xsd:enumeration value="A_UTF8STRING"/>
            <xsd:enumeration value="A_UNICODE2STRING"/>
            <xsd:enumeration value="A_BYTEFIELD"/>
        </xsd:restriction>
    </xsd:simpleType>
And here is generated Ecore (in OCLinEcore):
	enum DATATYPE { serializable }
		annotation _'http:///org/eclipse/emf/ecore/util/ExtendedMetaData'
			name = 'DATA-TYPE'
		literal AINT32;
		literal AUINT32 = 1;
		literal AFLOAT32 = 2;
		literal AFLOAT64 = 3;
		literal AASCIISTRING = 4;
		literal AUTF8STRING = 5;
		literal AUNICODE2STRING = 6;
		literal ABYTEFIELD = 7;
dave
Re: [XSD2Ecore] is removing removing underscore from EEnumLiteral name and not setting literal [message #984738 is a reply to message #984678] Wed, 14 November 2012 18:28 Go to previous messageGo to next message
Member
The same problem is happening with dash separated literal names as well. In the dash case the dashes do have to be removed to make them valid Java names, but in that case the literal should have the "unaltered value of the enumeration facet" according to 9.2.2 in the EMF book, correct?
Here is a dash example:
    <xsd:simpleType name="VALID-TYPE">
            <xsd:enumeration value="VALID"/>
            <xsd:enumeration value="NOT-VALID"/>
            <xsd:enumeration value="NOT-DEFINED"/>
            <xsd:enumeration value="NOT-AVAILABLE"/>
        </xsd:restriction>
    </xsd:simpleType>
enum VALIDTYPE {
  VALID = 0;
  NOTVALID = 1;
  NOTDEFINED = 2;
  NOTAVAILABLE = 3;
dave
[Updated on: Wed, 14 November 2012 18:29]
Report message to a moderator
Re: [XSD2Ecore] is removing removing underscore from EEnumLiteral name and not setting literal [message #985005 is a reply to message #984678] Wed, 14 November 2012 23:39 Go to previous message
Ed Merks is currently offline Ed Merks
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
David,<br>
<br>
Comments below.<br>
<br>
<div class="moz-cite-prefix">On 14/11/2012 11:21 PM, David Rees
wrote:<br>
</div>
<blockquote cite="mid:k815gn$q1u$1@xxxxxxxxe.org" type="cite">I'm
set to original value either. </blockquote>
No, the literal is set properly.<br>
<br>
  /**<br>
   * The '&lt;em&gt;&lt;b&gt;AFLOAT&lt;/b&gt;&lt;/em&gt;' literal
value.<br>
   * &lt;!-- begin-user-doc --&gt;<br>
   * &lt;p&gt;<br>
   * If the meaning of
'&lt;em&gt;&lt;b&gt;AFLOAT&lt;/b&gt;&lt;/em&gt;' literal object
isn't clear,<br>
   * there really should be more of a description here...<br>
   * &lt;/p&gt;<br>
   * &lt;!-- end-user-doc --&gt;<br>
   * @see #AFLOAT<br>
<b>   * @model literal="A_FLOAT"</b><br>
   * @generated<br>
   * @ordered<br>
   */<br>
  public static final int AFLOAT_VALUE = 0;<br>
<br>
<blockquote cite="mid:k815gn$q1u$1@xxxxxxxxe.org" type="cite">I'll
<br>
</blockquote>
Technically the name is valid as long as it doesn't contain
characters that aren't valid Java characters and NCName allows many
such characters.  But in general we convert names to use Camel
casee...<br>
<br>
<br>
</blockquote>
That's just how it works.  You can use Ecore annotations to specify
exactly the name you want.<br>
<br>
<br>
dave
<br>
<br>
<br>
<br>
   &lt;xsd:simpleType name="DATA-TYPE"&gt;
<br>
       &lt;xsd:restriction base="xsd:string"&gt;
<br>
           &lt;xsd:enumeration value="A_INT32"/&gt;
<br>
           &lt;xsd:enumeration value="A_UINT32"/&gt;
<br>
           &lt;xsd:enumeration value="A_FLOAT32"/&gt;
<br>
           &lt;xsd:enumeration value="A_FLOAT64"/&gt;
<br>
           &lt;xsd:enumeration value="A_ASCIISTRING"/&gt;
<br>
           &lt;xsd:enumeration value="A_UTF8STRING"/&gt;
<br>
           &lt;xsd:enumeration value="A_UNICODE2STRING"/&gt;
<br>
           &lt;xsd:enumeration value="A_BYTEFIELD"/&gt;
<br>
       &lt;/xsd:restriction&gt;
<br>
   &lt;/xsd:simpleType&gt;
<br>
<br>
<br>
<br>
<br>
<br>
<br>
        annotation
_'<a class="moz-txt-link-freetext" href="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">http:///org/eclipse/emf/ecore/util/ExtendedMetaData</a>'
<br>
<br>
            name = 'DATA-TYPE'
<br>
<br>
        literal AINT32;
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
It looks like they're not converting the literal value.<br>
<br>
<br>
dave
<br>
</blockquote>
<br>
</body>
</html>
Previous Topic:Problem referencing another emf project
Next Topic:[CDO] CDOAdmin - NullPointerException on Server side using TCP connector
Current Time: Sat May 18 10:04:31 EDT 2013
Powered by FUDForum. Page generated in 0.01828 seconds
