Home » Eclipse Projects » EclipseLink » Pagination - FIRST_ROWS_N
Pagination - FIRST_ROWS_N [message #984557] Wed, 14 November 2012 15:09 Go to next message
Mauro Flores is currently offline Mauro Flores
Member
How to create a JPA query with pagination parameters (setFirstRows and setMaxRows) and obtain a SQL query like this to run on oracle data base:
SELECT * FROM (SELECT /*+ FIRST_ROWS_10 / a., ROWNUM rnum FROM (...)
Today the SQL query is generated like:
SELECT * FROM (SELECT /*+ FIRST_ROWS / a., ROWNUM rnum FROM (...)
The second way is far slower than the first.
Is there a query hint to make this customization? I'm using eclipselink 2.1.3.
Thanks. Mauro Flores.
[Updated on: Wed, 14 November 2012 15:10]
Report message to a moderator
Re: Pagination - FIRST_ROWS_N [message #984628 is a reply to message #984557] Wed, 14 November 2012 16:24 Go to previous message
Chris Delahunt is currently offline Chris Delahunt
Depending on the database version you are on, not including the FIRST_ROWS at all might be more efficient as described here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=374136
If you can use EclipseLink 2.4 or later, with an Oracle10Platform or higher the hint will not be included. If this isn't what you need, please file an enhancement request to have the hint string used in pagination be configurable.
In the mean time, the bug fix mentioned above changed the hint string to a protected class instance, so in EclipseLink 2.4 you would need a custom platform subclass that sets the HINT set in the constructor to something else. In prior versions the HINT string is static and final, and so a platform subclass would need to override the printSQLSelectStatement method defined in the OraclePlatform class to print something different.
Best Regards,
Chris
Previous Topic:How to ise dynamic fetchgroup
Next Topic:Postgres inet type
Current Time: Sat May 25 23:58:31 EDT 2013
Powered by FUDForum. Page generated in 0.01511 seconds
