| My question to specialist of MARTE [message #969469] |
Sat, 03 November 2012 04:37  |
Ann barry Messages: 27 Registered: November 2012 |
Junior Member |
Hello every specialists,
i am interested in modeling but fresh with MARTE so i began reading on the specification promoted by OMG,
now i try to perform these specifications on Papyrus
but i dont know from when i must start
by your experience, what is the best practical guide to begin with implementing these specification ?
Best regards
Ann barry
| Re: My question to specialist of MARTE [message #985088 is a reply to message #984551] |
Thu, 15 November 2012 01:19   |
Lorea Belategi Messages: 5 Registered: September 2012 |
Junior Member |
Hi Ann,
It doesn't matter which subprofile are you going to use from MARTE, as you can apply the all sub profiles to the model. But at the time to annotate with the stereotypes, you will use those related to the subprofile of time. I don't know I explained properly. In your case, if you are modeling a sequence diagram, you might annotate with stereotypes, the messages between lifelines for example or annotate a timedElement. I never used time subprofile, so this might not be correct. But anyway, when you want to add an stereotype to an element (class, message, lifeline,etc.) of your model, only the available stereotypes for that element will be shown (at least in Papyrus).
Lorea.
| Re: My question to specialist of MARTE [message #985273 is a reply to message #985164] |
Thu, 15 November 2012 04:19   |
Junior Member |
Hi Ann,
MARTE profile has certain stereotypes defined in each subprofile. In my case, I have used stereotypes from SAM and PAM sub profiles (just to try how MARTE works). So, when applying them in my model diagrams (class, sequence and deployment), stereotypes that are able to apply to each element are shown. But I also have defined another profile with other kind of information. And apply it to the same model.
Thus, when applying a stereotype to a lifeline such as <<PaRunTInstance>> (from MARTE) I have also the possibility to add a <<kernel>> stereotype (defined in my profile extending the lifeline metaclass). But the stereotypes defined for classes can't be seeing.
So, if you want to use MARTE profile, you have to use the stereotypes defined in it (although you can extend the profile if you need) and you can also add new stereotypes defining another profile.
Does this answer your question?
Lorea.
FUDForum. Page generated in 0.02814 seconds
