Home » Eclipse Projects » BIRT » Dynamic Data source binding
Dynamic Data source binding [message #984201] Wed, 14 November 2012 08:46
Serge Coulon is currently offline Serge Coulon
I am trying to use BIRT (V4.2.1) to generate Oracle database reports based on SQL "AWR like" queries.
The requirement is to be able to select the target Oracle instance with some details like username/password, host, port, ...
I have tried to play with the Data Source Property Binding but it fails : Test Connection fails with "There is an error in get connection" even if I use constant strings for User Name or Password in the Property Binding fields.
What is wrong? What would be the best and easiest way to select the target instance at run time?
Serge
Previous Topic:Internationalized characters not displaying properly
Next Topic:Wrong scale of y-Axis in Logaritmic Format
Current Time: Sun May 19 16:42:59 EDT 2013
Powered by FUDForum. Page generated in 0.01450 seconds
