Home » Eclipse Projects » DSDP - Mobile Tools for Java (MTJ) » passing a parameter or a value of a variable to another activity every 10seconds?(How can i pass a parameter or a value of a variable to another activity every 10seconds?)
passing a parameter or a value of a variable to another activity every 10seconds? [message #983830] Wed, 14 November 2012 02:16
WESIANG LIM is currently offline WESIANG LIM
i am developing an android mobile phone application.
That application consists of two activity.
First - main activity
Second - AlarmSystem
What the idea is that, i will get the temperature of the battery, and then, i hope every 10 second i can check the temperature of the battery, then i will send that value of temperature of battery to the alarm system. if that temperature exceed certain point, then the alarm system will be alert.
My problem is, how to send in every 10 sec?
i am using API 4.1.2.
Previous Topic:Guide me on network path in new file () eclipse android
Next Topic:build error - .mtj.tmp\emulation (Access is denied)
Current Time: Wed May 29 02:36:23 EDT 2013
Powered by FUDForum. Page generated in 0.01426 seconds
