Home » Modeling » ATL » Why is the ATL editor removing the drop keyword?
Why is the ATL editor removing the drop keyword? [message #982842] Tue, 13 November 2012 08:12 Go to next message
Andreas Brieg is currently offline Andreas Brieg
Member
I have a small ATL transformation for refining mode. When I'm formatting the whole file, the drop keyword is removed.
The transformation looks like this:
-- @atlcompiler atl2010
-- @nsURI Java=http://www.eclipse.org/MoDisco/Java/0.2.incubation/java
module DropIfStatements;
create outputJava: Java refining javaInput: Java;
rule dropIfStatements {
	from
		ifStatement: Java!IfStatement
	to drop
I'm using Juno on Windows 64 Bit with the ATL SDK 3.3.1
Why is the keyword removed?
Re: Why is the ATL editor removing the drop keyword? [message #983021 is a reply to message #982842] Tue, 13 November 2012 11:04 Go to previous messageGo to next message
Hugo Bruneliere is currently offline Hugo Bruneliere
It seems like a small bug of the ATL Format Code feature.
Could you submit a bug related to this via this link https://bugs.eclipse.org/bugs/enter_bug.cgi?product=MMT.ATL&component=UI?
Hugo
Hugo Bruneliere - R&D Engineer
AtlanMod research team (Inria, EMN & LINA)
Ecole des Mines de Nantes
Nantes - France
Re: Why is the ATL editor removing the drop keyword? [message #983829 is a reply to message #983021] Wed, 14 November 2012 02:14 Go to previous message
Member
Bug is created.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=394245
Previous Topic:Generation code source
Next Topic:Why does a statement that was removed from it's block still appear in the serialized model?
Current Time: Sat May 25 09:23:35 EDT 2013
Powered by FUDForum. Page generated in 0.01552 seconds
