| Converting IFile to IDocument [message #982652] |
Tue, 13 November 2012 04:54  |
Kivanc Muslu Messages: 128 Registered: November 2010 |
Hi all,
I was using the following method calls to convert an IFile to an IDocument:
IDocumentProvider provider = new TextFileDocumentProvider();
provider.connect(file); // file is of IFile
IDocument document = provider.getDocument(file);
provider.disconnect(file);
However, this code runs in a headless Eclipse instance that I create (with -nosplash option) and it turns out that running any code that requires UI operations (especially access to the UI Thread) is not a good idea for headless applications. For once, on Mac, it turns out that the UI thread can only be initialized with the main thread, which causes a couple of problems.
So, I was wondering whether there is a way to convert an IFile object to an IDocument object without touching UI thread (and/or code)?
Thanks in advance, best regards,
[Updated on: Tue, 13 November 2012 04:56] Report message to a moderator
| Re: Converting IFile to IDocument [message #983246 is a reply to message #982790] |
Tue, 13 November 2012 14:59   |
Hi Dani,
Thanks for the reply.
I have looked at the TextFileDocumentProvider#createFileInfo() code and created the following code sequence for my purposes:
ITextFileBufferManager manager = FileBuffers.getTextFileBufferManager();
LocationKind locationKind = LocationKind.IFILE;
IPath location = file.getFullPath();
manager.connect(location, locationKind, null);
ITextFileBuffer fileBuffer = manager.getTextFileBuffer(location, locationKind);
IDocument result = fileBuffer.getDocument();
manager.disconnect(location, locationKind, null);
return result;
When I run the code on the headless Eclipse application, I get the following error though: (the trace is quite long, sorry).
***WARNING: Display must be created on main thread due to Cocoa restrictions.
!ENTRY org.eclipse.equinox.preferences 4 2 2012-11-13 11:51:48.486
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.equinox.preferences".
!STACK 0
java.lang.ExceptionInInitializerError
at org.eclipse.jdt.ui.PreferenceConstants.initializeDefaultValues(PreferenceConstants.java:3739)
at org.eclipse.jdt.internal.ui.JavaUIPreferenceInitializer.initializeDefaultPreferences(JavaUIPreferenceInitializer.java:38)
at org.eclipse.core.internal.preferences.PreferenceServiceRegistryHelper$1.run(PreferenceServiceRegistryHelper.java:300)
at org.eclipse.core.internal.preferences.PreferenceServiceRegistryHelper.runInitializer(PreferenceServiceRegistryHelper.java:303)
at org.eclipse.core.internal.preferences.PreferenceServiceRegistryHelper.applyRuntimeDefaults(PreferenceServiceRegistryHelper.java:131)
at org.eclipse.core.internal.preferences.PreferencesService.applyRuntimeDefaults(PreferencesService.java:368)
at org.eclipse.core.internal.preferences.DefaultPreferences.applyRuntimeDefaults(DefaultPreferences.java:166)
at org.eclipse.core.internal.preferences.DefaultPreferences.load(DefaultPreferences.java:237)
at org.eclipse.core.internal.preferences.EclipsePreferences.create(EclipsePreferences.java:410)
at org.eclipse.core.internal.preferences.EclipsePreferences.internalNode(EclipsePreferences.java:663)
at org.eclipse.core.internal.preferences.EclipsePreferences.node(EclipsePreferences.java:805)
at org.eclipse.core.internal.preferences.AbstractScope.getNode(AbstractScope.java:38)
at org.eclipse.core.runtime.preferences.DefaultScope.getNode(DefaultScope.java:76)
at org.eclipse.ui.preferences.ScopedPreferenceStore.getDefaultPreferences(ScopedPreferenceStore.java:250)
at org.eclipse.ui.preferences.ScopedPreferenceStore.getPreferenceNodes(ScopedPreferenceStore.java:285)
at org.eclipse.ui.preferences.ScopedPreferenceStore.internalGet(ScopedPreferenceStore.java:475)
at org.eclipse.ui.preferences.ScopedPreferenceStore.getBoolean(ScopedPreferenceStore.java:387)
at org.eclipse.jdt.internal.ui.preferences.MembersOrderPreferenceCache.install(MembersOrderPreferenceCache.java:61)
at org.eclipse.jdt.internal.ui.JavaPlugin.ensurePreferenceStoreBackwardsCompatibility(JavaPlugin.java:426)
at org.eclipse.jdt.internal.ui.JavaPlugin.start(JavaPlugin.java:373)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:300)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:263)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:469)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:395)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:464)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:340)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1212)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.core.internal.filebuffers.ExtensionsRegistry.getExtension(ExtensionsRegistry.java:227)
at org.eclipse.core.internal.filebuffers.ExtensionsRegistry.doGetDocumentSetupParticipants(ExtensionsRegistry.java:352)
at org.eclipse.core.internal.filebuffers.ExtensionsRegistry.getDocumentSetupParticipants(ExtensionsRegistry.java:369)
at org.eclipse.core.internal.filebuffers.ResourceExtensionRegistry.getDocumentSetupParticipants(ResourceExtensionRegistry.java:119)
at org.eclipse.core.internal.filebuffers.ResourceTextFileBufferManager.createEmptyDocument(ResourceTextFileBufferManager.java:144)
at org.eclipse.core.internal.filebuffers.ResourceTextFileBuffer.initializeFileBufferContent(ResourceTextFileBuffer.java:285)
at org.eclipse.core.internal.filebuffers.ResourceFileBuffer.create(ResourceFileBuffer.java:245)
at org.eclipse.core.internal.filebuffers.TextFileBufferManager.connect(TextFileBufferManager.java:112)
at com.kivancmuslu.www.solstice.eclipse.ResourceUtility.convertToDocument(ResourceUtility.java:125)
at com.kivancmuslu.www.solstice.logic.serialization.FileSerialization.deserializeToDocument(FileSerialization.java:45)
at com.kivancmuslu.www.solstice.logic.serialization.TextSelectionSerialization.deserialize(TextSelectionSerialization.java:58)
at com.kivancmuslu.www.solstice.client.logic.SolsticeElementChangedNotifier.processTextSelectionChangedMessage(SolsticeElementChangedNotifier.java:41)
at com.kivancmuslu.www.solstice.client.SolsticeClient.processTextSelectionChangedMessage(SolsticeClient.java:140)
at com.kivancmuslu.www.solstice.client.SolsticeClient.processMessage(SolsticeClient.java:132)
at com.kivancmuslu.www.solstice.client.SolsticeClientThread.run(SolsticeClientThread.java:70)
at java.lang.Thread.run(Thread.java:680)
Caused by: org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:4361)
at org.eclipse.swt.SWT.error(SWT.java:4276)
at org.eclipse.swt.SWT.error(SWT.java:4247)
at org.eclipse.swt.widgets.Display.error(Display.java:1068)
at org.eclipse.swt.widgets.Display.createDisplay(Display.java:825)
at org.eclipse.swt.widgets.Display.create(Display.java:808)
at org.eclipse.swt.graphics.Device.<init>(Device.java:130)
at org.eclipse.swt.widgets.Display.<init>(Display.java:699)
at org.eclipse.swt.widgets.Display.<init>(Display.java:690)
at org.eclipse.swt.widgets.Display.getDefault(Display.java:1386)
at org.eclipse.jface.preference.PreferenceConverter.<clinit>(PreferenceConverter.java:81)
... 61 more
!ENTRY org.eclipse.osgi 4 0 2012-11-13 11:51:48.494
!MESSAGE An error occurred while automatically activating bundle org.eclipse.jdt.ui (160).
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.jdt.internal.ui.JavaPlugin.start() of bundle org.eclipse.jdt.ui.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
Caused by: org.eclipse.core.runtime.AssertionFailedException: null argument:
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:85)
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:73)
at org.eclipse.jface.resource.FontRegistry.<init>(FontRegistry.java:283)
at org.eclipse.jface.resource.FontRegistry.<init>(FontRegistry.java:308)
at org.eclipse.jface.resource.JFaceResources.getFontRegistry(JFaceResources.java:342)
at org.eclipse.jdt.internal.ui.JavaPlugin.ensurePreferenceStoreBackwardsCompatibility(JavaPlugin.java:448)
... 37 more
Root exception:
!ENTRY org.eclipse.equinox.registry 4 1 2012-11-13 11:51:48.496
!MESSAGE Plug-in org.eclipse.jdt.ui was unable to load class org.eclipse.jdt.internal.ui.javaeditor.JavaDocumentSetupParticipant.
!STACK 0
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.jdt.ui (160).
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:122)
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.jdt.internal.ui.JavaPlugin.start() of bundle org.eclipse.jdt.ui.
... 31 more
... 37 more
!ENTRY org.eclipse.equinox.registry 4 1 2012-11-13 11:52:16.140
!STACK 0
... 31 more
... 37 more
!ENTRY org.eclipse.equinox.registry 4 1 2012-11-13 11:52:16.142
!STACK 0
... 31 more
... 37 more
!ENTRY org.eclipse.equinox.registry 4 1 2012-11-13 11:52:27.484
!STACK 0
... 31 more
... 37 more
!ENTRY org.eclipse.equinox.registry 4 1 2012-11-13 11:52:27.486
!STACK 0
... 31 more
... 37 more
It looks like ITextFileBufferManager#connect indirectly tries to access the UI thread again, causing similar exceptions. Shall I try using ITextFileBuffer without getting them through the manager?
Thank you,
| Re: Converting IFile to IDocument [message #984060 is a reply to message #983246] |
Wed, 14 November 2012 06:13   |
Dani Megert Messages: 3801 Registered: July 2009 |
On 13.11.2012 20:59, Kivanc Muslu wrote:
> Hi Dani,
> locationKind);
> return result;
> restrictions.
This indicates that you also have UI plug-ins in your target. They can
extend core bundles and will be loaded if needed. You need to remove the
ui bundles from your target.
Dani
> !STACK 0
> at
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 61 more
> !STACK 0
> org.eclipse.jdt.ui.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> argument:
> at
> at
> at
> at
> at
> at
> ... 37 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.jdt.ui.
> at
> at
> at
> at
> at
> at
> at
> ... 31 more
> argument:
> at
> at
> at
> at
> at
> at
> ... 37 more
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.jdt.ui.
> at
> at
> at
> at
> at
> at
> at
> ... 31 more
> argument:
> at
> at
> at
> at
> at
> at
> ... 37 more
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.jdt.ui.
> at
> at
> at
> at
> at
> at
> at
> ... 31 more
> argument:
> at
> at
> at
> at
> at
> at
> ... 37 more
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.jdt.ui.
> at
> at
> at
> at
> at
> at
> at
> ... 31 more
> argument:
> at
> at
> at
> at
> at
> at
> ... 37 more
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.jdt.ui.
> at
> at
> at
> at
> at
> at
> at
> ... 31 more
> argument:
> at
> at
> at
> at
> at
> at
> ... 37 more
> Thank you,
| Re: Converting IFile to IDocument [message #985246 is a reply to message #985232] |
Thu, 15 November 2012 04:03   |
Is there a way for me to diagnose (which bundle creates the problem) and make sure that it is not loaded. What might be the reason of that bundle loading?
Thank you,
Edit: I thought that the way I create the headless Eclipse in my plug-in (i.e., internal Eclipse), might help, here is the code:
// Get Eclipse workspace location and hash it.
String wsPath = ResourceUtility.getInstance().getWorkspacePath();
String workspacePostfix = Checksum.getInstance().hashToHexString(wsPath);
String eclipseExecutable = System.getProperty("eclipse.launcher");
String shadowWorkspacePath = CommonConstants.SHADOW_WORKSPACE_ROOT + CommonConstants.PS
+ workspacePostfix;
// We cannot have -consoleLog switch on Windows environment as it creates a command line
// for the headless Eclipse, which kills all the idea of being headless. Until we have a
// better solution, let's detect the OS and don't pass that switch when it is Windows.
ArrayList<String> eclipseArguments = new ArrayList<String>();
eclipseArguments.add(eclipseExecutable);
String osName = System.getProperty("os.name");
boolean isWindows = isWindows(osName);
if (!isWindows)
eclipseArguments.add("-consoleLog");
eclipseArguments.add("-data");
eclipseArguments.add(shadowWorkspacePath);
eclipseArguments.add("-nosplash");
eclipseArguments.add("-application");
eclipseArguments.add("com.kivancmuslu.www.solstice.client.application");
Process process = Runtime.getRuntime()
.exec(eclipseArguments.toArray(new String[eclipseArguments.size()]));
[Updated on: Thu, 15 November 2012 04:35] Report message to a moderator
| Re: Converting IFile to IDocument [message #986092 is a reply to message #985246] |
Sun, 18 November 2012 13:05  |
Stephan Herrmann Messages: 779 Registered: July 2009 |
Kivanc Muslu wrote on Thu, 15 November 2012 10:03Is there a way for me to diagnose (which bundle creates the problem) and make sure that it is not loaded. What might be the reason of that bundle loading?
Have you tried this: in your launch configuration deselect all plug-ins, select your own plug-ins and click "Add required plug-ins", which should give you the minimal transitive closure of dependencies?
FUDForum. Page generated in 0.02351 seconds
