Home » Eclipse Projects » Plugin Development Environment (PDE) » 0.0.0 versions in .target file
0.0.0 versions in .target file [message #857077] Thu, 26 April 2012 04:12 Go to next message
Eclipse User
Hej,
I'm observing a strange behaviour of PDE when setting a target platform
requiring InstallableUnits with versions of '0.0.0'. Consider this
target file:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<?pde version="3.6"?>
<target name="test" sequenceNumber="0">
<locations>
<location includeAllPlatforms="false" includeMode="planner"
includeSource="false" type="InstallableUnit">
<repository id="foo" location="https://foo/"/>
<repository id="bar" location="https://bar/"/>
<unit id="baz" version="0.0.0"/>
</location>
</locations>
</target>
The unit with the id 'baz' is deployed to both repositories 'foo' and
'bar' with different version identifiers:
foo: 1.0.0.v1234
1.0.0.v2345
2.0.0.v1234
bar: 1.0.0.SNAPSHOT-1234
2.0.0.SNAPSHOT-2345
When setting this target platform, PDE should use the artifact with the
largest qualifier (2.0.0.v1234, when I got this right) considering _all_
locations. But mostly it uses some other artifact, not the one with the
largest version.
I'm using such .target files within my tycho builds, and with tycho
there are obviously no problems getting the unit with the largest
version, even if it is deployed to more than one p2 repository.
Is this a bug or an unsupported feature? Any comment is greatly
appreciated. Regards,
Mirko Swillus
Re: 0.0.0 versions in .target file [message #889996 is a reply to message #857077] Wed, 20 June 2012 10:14 Go to previous messageGo to next message
Matthias Steigenberger is currently offline Matthias Steigenberger
I'm considering the same problem.
It's an unsupported feature but it would be nice to support it.
Please file a bug report.
Re: 0.0.0 versions in .target file [message #982785 is a reply to message #857077] Tue, 13 November 2012 07:19 Go to previous messageGo to next message
Lars Fischer is currently offline Lars Fischer
any news on this issue?
Is there an existing bugzilla entry to vote for?
Lars
Re: 0.0.0 versions in .target file [message #986755 is a reply to message #982785] Wed, 21 November 2012 09:43 Go to previous message
I filed a new bugzilla entry for this: https://bugs.eclipse.org/bugs/show_bug.cgi?id=394788
Previous Topic:create eclipse e4 update sites for non-RCP applications
Next Topic:Detach through code
Current Time: Sat May 25 17:41:26 EDT 2013
Powered by FUDForum. Page generated in 0.01633 seconds
