Home » Eclipse Projects » Rich Client Platform (RCP) » run multiple instances of "eclipse 4 application project(run multiple instances of "eclipse 4 application project)
run multiple instances of "eclipse 4 application project [message #975795] Wed, 07 November 2012 23:45 Go to next message
Max Paulsen is currently offline Max Paulsen
Hi all!
I want to launch multiple instances of an eclipse 4 application project.
Whenever I try to start the app a second time, a dialog box appears saying:
Could not launch the current application because the associated workspace is in
use by another Eclipse application
Path\xyz.product
Buttons: Edit... Exit
Is there a way to add a flag in the launch config which allows more instances?
Do I have to handle that programmatically ?
Thanks for help
Max
Re: run multiple instances of &quot;eclipse 4 application project [message #976407 is a reply to message #975795] Thu, 08 November 2012 09:56 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas Schindl
No not yet - not sure there's a bug for this yet to not create a lock
file. You need to search bugzilla and if you can't find one file it.
Tom
Am 08.11.12 14:59, schrieb Max Paulsen:
> Hi all!
> workspace is in
> Path\xyz.product
> instances?
> Thanks for help
> Max
Re: run multiple instances of &quot;eclipse 4 application project [message #977463 is a reply to message #976407] Fri, 09 November 2012 04:55 Go to previous messageGo to next message
sumit singh is currently offline sumit singh
Member
Yes u can't do it programmatically. but manually u can do some workaround.
1. open run configuration
2. create new eclipse product with same configuration.
3. add all required the plugin.
4. now u can run 2 instance of your application by using 2 run configuration.
Re: run multiple instances of &quot;eclipse 4 application project [message #982164 is a reply to message #977463] Mon, 12 November 2012 19:45 Go to previous message
Thank you for help!
I have to handle proammatically the start of N (N>1) instances of the same eclipse 4 application project.
Could you please describe how to do that?
Thanks in advance
Max
Previous Topic:Adding PDFRenderder.jar to my Plug-In Project - Runtime Error
Next Topic:How to register adapter factory for ResourceMapping?
Current Time: Thu May 23 23:15:17 EDT 2013
Powered by FUDForum. Page generated in 0.01703 seconds
