Home » Modeling » MoDisco » Programmatically get kdm instance v0.10
Programmatically get kdm instance v0.10 [message #977895] Fri, 09 November 2012 12:16 Go to next message
Daniel San Martín is currently offline Daniel San Martín
Basically, I want to create a eclipse plug-in or reuse the modisco project to discover and generate the kdm instance programmatically (kdm from java project) with version 0.10.
If I create a eclipse plug-in, which are the plugs-in dependencies? and which code I must write to get it work? on the other hand, if I choose to reuse the modisco project
what do I have to do?.
Thanks in advance,
Daniel.
Re: Programmatically get kdm instance v0.10 [message #981773 is a reply to message #977895] Mon, 12 November 2012 12:30 Go to previous messageGo to next message
Hugo Bruneliere is currently offline Hugo Bruneliere
I encourage you to take a look to the KDM Discoverer documentation (Developer part) from the MoDisco reference doc.
This notably explains how to call such a discoverer programmatically.
Hugo
Hugo Bruneliere - R&D Engineer
AtlanMod research team (Inria, EMN & LINA)
Ecole des Mines de Nantes
Nantes - France
Re: Programmatically get kdm instance v0.10 [message #981963 is a reply to message #981773] Mon, 12 November 2012 16:02 Go to previous message
Thank you very much for publish the modisco documentation, version 0.10. Very Happy
Previous Topic:startLine and endLine attributes
Next Topic:How to Load JavaModel (file.javaxmi)
Current Time: Tue May 28 18:56:24 EDT 2013
Powered by FUDForum. Page generated in 0.01600 seconds
