Home » Language IDEs » CDT » Compiling same project with different compilers(Compiling with gcc and arm-none-eabi-gcc the same source files)
Compiling same project with different compilers [message #981735] Mon, 12 November 2012 11:56
MASSIMO MANCA is currently offline MASSIMO MANCA
I normally work in embedded projects using ARM microcontrollers. So to simplify initial testing I use the GCC PC/Windows compiler and then I switch to the arm-none-eabi-gcc compiler. Now I would be able to compile the same project source files with both compilers. So to make a try I have Debug and Release for the ARM GCC compiler and PC-Debug, PC-Release to setup the GCC Windows compiler. The problem is that when I switch back from a compiler to the other one the project is a little bit corrupted (I suppose) because the compiler doesn't find the right include directories and sometimes also the make.exe
Any idea useful to solve my problem?
Previous Topic:Progress information Configuring GDB hangs
Next Topic:MISRA C Checker for Codan
Current Time: Mon May 20 13:29:04 EDT 2013
Powered by FUDForum. Page generated in 0.01473 seconds
