Home » Eclipse Projects » BPMN 2.0 Modeler » SubProcesses
SubProcesses [message #981209] Mon, 12 November 2012 03:37 Go to next message
Tom Kohler is currently offline Tom Kohler
I will use SubProcesses I cannot map the properties from the surrounding process to the sub process. Is this functionality still missing?
Thanks Thomas
Re: SubProcesses [message #985732 is a reply to message #981209] Thu, 15 November 2012 16:00 Go to previous messageGo to next message
Robert Brodt is currently offline Robert Brodt
Hi Thomas,
I've created https://bugs.eclipse.org/bugs/show_bug.cgi?id=394423 to track this. Please verify and let me know if this is what you are seeing.
Bob
Re: SubProcesses [message #988995 is a reply to message #985732] Tue, 04 December 2012 03:26 Go to previous messageGo to next message
Hello Bob,
I checked your description and it is correct.
Thanks Thomas
Re: SubProcesses [message #988998 is a reply to message #988995] Tue, 04 December 2012 04:03 Go to previous message
Hello Bob,
I also tried an other scenario with SubProcesses:
1. Create a new Project and select "JBoss jBPM5 Business Process Engine" for BPMN2 Target Runtime.
2. Create a new BPMN2 Process file named processA.bpmn
3. DND a Start Event onto the canvas
4. DND a End Event onto the canvas
5. DND a Script Task onto the canvas
6. Open Script Task property view and add 'System.out.println("Hello");' to the Script Attribute
7. Create a SequenceFlow between Start - Script Task and ScriptTask - End
8. Create a new BPMN2 Process file named processB.bpmn
9. DND a Start Event onto the canvas
10. DND a End Event onto the canvas
11. DND a Call Activity onto the canvas
12. Edit Call Activity and select process as a type of callable element
13. Add the following parameter to the create new process dialog:
- id id of the processA
- name name of the processA
If you display the source code you see that a process object with id processA is created in the processB.bpmn file. If the process tag will be removed the modeller creates a UnresolvedReferenceException
How is it possible to refer a process which is design in its own file?
Thanks Thomas
Previous Topic:Future of Project
Next Topic:Version 0.2.0 now available
Current Time: Sun May 26 04:21:03 EDT 2013
Powered by FUDForum. Page generated in 0.01788 seconds
