| How to open a Papyrus editor programmatically [message #698676] |
Tue, 19 July 2011 20:10  |
Miles Parker Messages: 1266 Registered: July 2009 |
For testing purposes, I need to be able to open a Papyrus editor programmatically. But the usual approach doesn't work. For:
UmlGmfDiagramEditor ed = (UmlGmfDiagramEditor) page.openEditor(input, "org.eclipse.papyrus.core.papyrusEditor");
I get:
Caused by: org.eclipse.papyrus.core.extension.NotFoundException: No ContentOutline registered.
at org.eclipse.papyrus.core.contentoutline.ContentOutlineRegistry.getContentOutlineDescriptor(ContentOutlineRegistry.java:98)
at org.eclipse.papyrus.core.contentoutline.ContentOutlineRegistry.createContentOutline(ContentOutlineRegistry.java:112)
at org.eclipse.papyrus.core.contentoutline.ContentOutlineRegistry.getContentOutline(ContentOutlineRegistry.java:72)
at org.eclipse.papyrus.core.editor.CoreMultiDiagramEditor.getAdapter(CoreMultiDiagramEditor.java:363)
... 74 more
How should I accomplish this?
thanks,
Miles
| Re: How to open a Papyrus editor programmatically [message #699332 is a reply to message #698676] |
Thu, 21 July 2011 07:27   |
Cedric Dumoulin Messages: 31 Registered: July 2009 |
Member |
Sound like a bug. Can you report it in Bugzilla ?
When starting, Papyrus check if there is some registered
contentOutline. If one or more are found, Papyrus takes the one with the
highest priority. If none is found, Papyrus should fails silently. This
seem to be not the case.
As a workaround, you can try to add the simplest contentoutline
(plugins/other/org.eclipse.papyrus.outline) plugins in your test
environement.
Hope this help,
Cedric
> I get:
> at
> at
> at
> at
> ... 74 more
> thanks,
> Miles
| Re: How to open a Papyrus editor programmatically [message #978658 is a reply to message #977929] |
Sat, 10 November 2012 02:44  |
Beatus Ding Messages: 18 Registered: November 2012 |
Junior Member |
so sorry to mis-paste error information,the real error as follows:
org.eclipse.ui.PartInitException: Unable to open editor, unknown editor ID: org.eclipse.papyrus.core.papyrusEditor
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3025)
at org.eclipse.ui.internal.WorkbenchPage.access$22(WorkbenchPage.java:3003)
at org.eclipse.ui.internal.WorkbenchPage$8.run(WorkbenchPage.java:2985)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2981)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2940)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2931)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:751)
at unfinishedplugin.actions.SampleAction.openEditor(SampleAction.java:195)
at unfinishedplugin.actions.SampleAction.run(SampleAction.java:100)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:251)
at org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPluginAction.java:229)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$6.handleEvent(ActionContributionItem.java:452)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1029)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:923)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
I think it's the same with you~and the bug you posted doesn't exist,so can you tell how you solved the problem,thanks~
FUDForum. Page generated in 0.01902 seconds
