Home » Eclipse Projects » Orion » How to write a command that provisions a file into the user's directory?
How to write a command that provisions a file into the user's directory? [message #968813] Fri, 02 November 2012 15:29 Go to next message
Rafael Chaves is currently offline Rafael Chaves
I would like my plugin to contribute a navigator command that will add a file to the selected directory. Is that currently possible (from a plugin)?
Concrete case: in Cloudfier, a project has a related database. I want to allow the user to capture the current database's state as a JSON file in their project directory.
My workaround for now requires the user to create an empty file, open it in the text editor, and trigger a editor command that will insert the database contents into the text editor buffer, which the user can then save.
Re: How to write a command that provisions a file into the user's directory? [message #968854 is a reply to message #968813] Fri, 02 November 2012 16:17 Go to previous messageGo to next message
The orion.navigate.content service feels a bit like what I need:
http://wiki.eclipse.org/Orion/Documentation/Developer_Guide/Plugging_into_the_navigator#orion.navigate.content
However, it is meant to "create new top level folders with autogenerated content" (like the "Clone git Repository" and "SFTP Import" commands), and all I want is to create a new file (on the selected directory), and need a way of streaming the contents of the file so Orion can actually create the file (or a handle to the flie client API).
[Updated on: Fri, 02 November 2012 16:19]
Report message to a moderator
Re: How to write a command that provisions a file into the user's directory? [message #978048 is a reply to message #968813] Fri, 09 November 2012 15:13 Go to previous message
John Arthorne is currently offline John Arthorne
For reference, this conversation moved into a bug report:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=393986
Previous Topic:Async highlighter
Next Topic:Security Handshake
Current Time: Wed May 22 22:52:37 EDT 2013
Powered by FUDForum. Page generated in 0.10317 seconds
